Search the Community
Showing results for tags 'channel switch'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 2 results
  1. OS: Windows 10, 64bit. Tuner: TBS 5980. Sattelite: 4.9 Astra and 36.0 Eutelsat (connected via DiseqC). Software: Recording Service + Kodi. Problem: sometimes on channel switch Recording Service hangs up. Last part of log file (svcdebug.log): 27.05.16 11:42:10.904 TBDACITBSModule CI Base SetTuner Entering 27.05.16 11:42:10.904 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 11:42:11.034 TBDACITBSModule WndProc Received PMT ready 27.05.16 11:42:13.173 TUPnPAnnounce InitWsocket 192.168.1.120 27.05.16 11:42:42.740 TRecordingEngine Resume Reset Timer signaled 27.05.16 11:42:42.740 Reset Start 27.05.16 13:14:12.028 TRecordingEngine Standby PBT_APMSUSPEND 27.05.16 13:14:12.029 TUPnPAnnounce Stopped 27.05.16 13:14:12.029 TRTSPWebserver Disconnected 27.05.16 13:14:12.037 Release TBS 5980 CI Tuner 27.05.16 13:14:12.037 Destroy TBS 5980 CI Tuner 27.05.16 13:14:13.043 Destroyed TBS 5980 CI Tuner 27.05.16 13:14:13.044 hamDeleted TBS 5980 CI Tuner 27.05.16 13:14:13.049 TSrvDataModule Freed 27.05.16 17:35:32.504 TRecordingEngine Time changed 27.05.16 17:35:32.737 TRecordingEngine Resume PBT_APMRESUMESUSPEND 27.05.16 17:35:32.737 TRecordingEngine Resume Processing... 27.05.16 17:35:32.737 TRecordingEngine Sleeping -1 27.05.16 17:35:32.737 ReleaseStandbyblock PBT_APMRESUMESUSPEND 27.05.16 17:35:32.740 TRecordingEngine FWakeUp do 27.05.16 17:35:32.740 TRecordingEngine NextEPGUpdate 5/28/2016 12:47:19 AM 27.05.16 17:35:32.740 TUPnPAnnounce Start 27.05.16 17:35:32.741 TUPnPAnnounce InitWsocket 127.0.0.1 27.05.16 17:35:32.758 TRecordingEngine Resume PBT_APMRESUMEAUTOMATIC 27.05.16 17:35:32.758 TRecordingEngine Resume Processing... 27.05.16 17:35:32.758 TRecordingEngine Sleeping 0 27.05.16 17:35:41.597 TBDA_TBS Opendevice bvTurbosight 27.05.16 17:35:41.597 TStreamClient AllocateHardware TBS 5980 CI Tuner 27.05.16 17:35:41.597 TBDA_TBS SetTuner TType: 1, Freq: 11996, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 305, VPID: 205, PMT: 1905, SID: 19105, TID: 19, NID: 112, SatMod: 6, DiseqCVal: 0, Flags: 25 27.05.16 17:35:42.309 TBDACITBSModule CI Base SetTuner Entering 27.05.16 17:35:42.309 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 17:35:42.507 TBDACITBSModule WndProc Received PMT ready 27.05.16 17:35:43.388 TUPnPAnnounce InitWsocket 192.168.1.120 27.05.16 17:36:12.734 TRecordingEngine Resume Reset Timer signaled 27.05.16 17:36:12.734 Reset Start 27.05.16 17:36:13.140 TStreamClient AllocateHardware TBS 5980 CI Tuner 27.05.16 17:36:13.141 TBDACITBSModule CI Base SetTuner Entering 27.05.16 17:36:13.141 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 17:36:13.389 TBDACITBSModule WndProc Received PMT ready 27.05.16 18:02:08.126 TBaseProcess API_HandleStatus 27.05.16 18:21:23.271 TStreamClient AllocateHardware TBS 5980 CI Tuner 27.05.16 18:21:23.272 TBDA_TBS SetTuner TType: 1, Freq: 12265, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 403, VPID: 323, PMT: 2903, SID: 31003, TID: 10, NID: 112, SatMod: 1, DiseqCVal: 0, Flags: 25 27.05.16 18:21:23.595 TBDACITBSModule CI Base SetTuner Entering 27.05.16 18:21:23.595 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 18:21:24.023 TBDACITBSModule WndProc Received PMT ready 27.05.16 19:22:15.126 Release TBS 5980 CI Tuner 27.05.16 19:22:15.127 Destroy TBS 5980 CI Tuner 27.05.16 19:22:16.154 Destroyed TBS 5980 CI Tuner 27.05.16 19:22:16.154 hamDeleted TBS 5980 CI Tuner 27.05.16 20:37:02.852 TBDA_TBS Opendevice bvTurbosight 27.05.16 20:37:02.852 TStreamClient AllocateHardware TBS 5980 CI Tuner 27.05.16 20:37:02.853 TBDA_TBS SetTuner TType: 1, Freq: 12265, Symrate: 27500, LOF: 10750, Tone: 0, Pol: 0, DiseqC: 3, FEC: 3, APID: 403, VPID: 323, PMT: 2903, SID: 31003, TID: 10, NID: 112, SatMod: 1, DiseqCVal: 0, Flags: 25 27.05.16 20:37:03.460 TBDACITBSModule CI Base SetTuner Entering 27.05.16 20:37:03.460 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 20:37:03.717 TBDACITBSModule WndProc Received PMT ready 27.05.16 20:46:11.125 TStreamClient AllocateHardware TBS 5980 CI Tuner 27.05.16 20:46:11.126 TBDA_TBS SetTuner TType: 1, Freq: 11843, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 0, DiseqC: 4, FEC: 3, APID: 6252, VPID: 6251, PMT: 6250, SID: 6250, TID: 13, NID: 85, SatMod: 1, DiseqCVal: 0, Flags: 25 27.05.16 20:46:11.768 TBDACITBSModule CI Base SetTuner Entering 27.05.16 20:46:11.768 TBDACITBSModule CI Base SetTuner Leaving 27.05.16 20:46:11.912 TBDACITBSModule WndProc Received PMT ready Neither Kodi, nor DVBViewer after this problem occurs, could not tune and show any TV channel. DVBViewer shows following error: Recording Service status hangs at "Stopping" state. The only way I can get TV back to work is to restart the PC or to restart service using command line: sc queryex DVBVRecorder taskkill /f /pid 1860 net start DVBVRecorder What could cause this sort of problem? Defective TBS driver? Recording Service bug?
  2. Good evening, i am trying for few weeks establish Satelite TV on XBMC 12 through recording service. Everything is working fine instead of switching channels. It will stuck on channel change. At lower right corner shows its doing something but program change does not work. I tried USB DVB-T dongle Aver Media - AVerTV Hybrid + FM Volar and worked great. Is something in configuration service which is specific for SKYSTAR? I must mention, that in DVBViever channels change without problem for SKYSTAR too. Using Windows 8 64-bit Professional. TechniSat Skystar USB HD 2 CI drivers version: 1.0.6.102. Downloaded somewhere from google. (have not found on offi site - it looks like they dont support this model anymore) Regards Martin
