Search the Community
Showing results for tags 'lav codec'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. minic
    UHD We aren't ?
    Hello! I've an workstation pc fueled with Intel I7-6800k, 32gb of ddr4 ram and and old GTX 580 I've used DVBViewer with lav filter 0.68.1, with this codec and my GPU is impossible to use the hardware GPU acceleration (not support h265 acceleration), and i will use only my 12 Core (Threaded) CPU This channel work ok: Fashion 4K [Astra 1L,DVB-S2,8PSK,11111 H 22000 2/3] PEARL TV 4K UHD [Astra 1H,DVB-S2,8PSK,12344 H 30000 2/3] This instead, didn't work, freeze and choppy frame (cpu go on 80%/90%)! HLG teststream [Astra 1M,DVB-S2,8PSK,10714 H 23500 3/4] Canal+ UHD [Astra 1N,DVB-S2,8PSK,12581 V 22000 2/3] SES UHD Demo Channel [Astra 1N,DVB-S2,8PSK,10993 H 22000 5/6] Well, i solved this problematic channel using another player (MPC) filled by net streaming plugin from DVBViewer... This player support x64, and i can use the 64bit codec lav... with this the video is very very fluid, and i use only 30% of my super cpu... Please support the x64 codec from DVBViewer.. is the only way to watch correctly the UHD channels.
