Search the Community
Showing results for tags 'problem tv decoding'.
Hello I bought DVBViewer pro yesterday and I have a problem. I tested before buying version DVBViewer 5.6.1 (pirate). In it everything worked and in the new version I have a problem. At home I have a tuner (enigma2) and in it legal cards "Cyfrowy Polsat" and "NC +". As I downloaded the DVBViewer 5.6.1 + [ removed, violating forum rule §13 ] 6.2.0 to my computer all my channels worked. I had only problem with Comedy Central Poland HD (DVBViewer crasch). I liked the program and bought the original. At this point, however, as far as the Comedy Central Poland HD works for me, a lot of channels do not work. Does not decode. Help 12:22:50.995: Ch: 272 - Puls 2 (pol) 12:22:50.995: Programm crc: E03144E0 12:22:50.995: Create ACamdTmp directory... 12:22:50.995: Not possible to create ACamdTmp directory... 12:22:50.995: Create ACamdTmp directory... 12:22:50.995: Not possible to create ACamdTmp directory... 12:22:51.955: Create ACamdTmp directory... 12:22:51.955: Not possible to create ACamdTmp directory... 12:22:51.971: Create ACamdTmp directory... 12:22:51.971: Not possible to create ACamdTmp directory... 12:22:51.971: PMT: ACamd_PMT.txt, search, not found PMT=0110 (AND SID=10E3) 12:22:51.971: 0x0110 0x10E3 0x0B01 0x00000000 0x084B 0x00C1 11111110 12:22:51.996: Create ACamdTmp directory... 12:22:51.996: Not possible to create ACamdTmp directory... 12:22:51.996: CCcamN 0: Current Share 00000065, CAID 0B01, Hops 0, NodeID 901D92F7105214CD 12:22:52.008: CCcamN 0: ECM [08AF][0B02/00000000] Pro (0.012) 12:22:52.008: CCcamN 0: ECM [08AF][0B02/00000000] not able to decode 12:22:52.072: Create ACamdTmp directory... 12:22:52.072: Not possible to create ACamdTmp directory...
