DVBViewer community forum: Recordingservice Beta - DVBViewer community forum
  • (4 Pages)
  • 1
  • 2
  • 3
  • Last »
  • You cannot start a new topic
  • This topic is locked
Recordingservice Beta Announcements
#1 User is offline   Lars_MQ
  • Administrator
  • PipPipPipPipPipPipPipPipPipPipPip
  • Group: Forum Admins
Posted 18 July 2007 - 18:13
A new Beta is in the membersarea.
Please post followups here
in deutsch
Quote
Installation:
You need Administrator rights.
IMPORTANT:
If you update a older beta of the service FIRST execute in folder COMPlugins the file "unregPlugs.bat" and delete the files "epgstore.dll" and "epgparser.dll"!
Extract the content of the zip file into the DVBViewer Pro folder. On first installation start installsvc.bat to register the service with windows. If you want to delete the service please run first uninstallsvc.bat.
The DVBViewer Recordingservice is a native windows service. It enables you to record programmed timers by the DVBViewer Pro without DVBViewer Pro.
Changes 1.3.0.0
- Fix: Memoryleak when working together with the web-Plugin.
- EPG-Updater integrated. - Settings can be done via the web-interface. Per default deactivated.
You can activate the EPG updater with the webinterface. You can also set the scantime per transponder (Muxx) in seconds.
The EPG-Updater creates a list of available transponders depending on the available devices and tunes them in the background to collect the epg-data.
When activated the updatescan starts 5 minutes after the start of the service. If the used device is needed for a recording the scan is interrupted.
After finishing the EPG-Update then EPG-Updater is deactivated for 12 hours, if the service isn't restarted in this time the process begins all over.
It works with DVB EPG, MHW, MHW+. It does NOT work with Portal-EPG and Sieh-Fern EPG.
- Web-Plugin: You can now configure if only radio, tv or both channeltypes are shown in the overview pages.
- The Web-Plugin now obeys the "exclude from EPG" from the DVBViewer channeleditor. These channels will not be shown in the overviews.
- Several optimizations in the Web-Plugin.
#2 User is offline   Lars_MQ
  • Administrator
Posted 19 July 2007 - 11:07
I've uploaded the version 1.3.1 as a Hotfix.
Fix: On some cards with CAM Modules the EPG-Updater caused the Service to crash. Sorry about that.
#3 User is offline   Lars_MQ
  • Administrator
Posted 06 August 2007 - 19:01
The Version 1.3.2 is in the Membersarea.
Changes:
brought uptodate with the current DVBViewer Pro release.
#4 User is offline   Lars_MQ
  • Administrator
Posted 09 October 2007 - 07:50
The Version 1.3.4 is in the Membersarea.
Changes:
#5 User is offline   Lars_MQ
  • Administrator
Posted 02 December 2007 - 06:59
Version 1.3.5 is in the Membersarea.
Changes:
- uptodate with the current DVBViewer Pro release.
- Fix no password in webplugin.
Attention:
The readme file now is in a subfolder named docs.
#6 User is offline   Lars_MQ
  • Administrator
Posted 25 January 2008 - 13:43
Version 1.4.0 is in the Membersarea.
extract from the readme:
Quote
The service now contains a cut down version of the webserver for DVB Viewer. It shows EPG data and helps to create/change/delete timers.
It is enabled automatically and uses as default Port 80/local host (127.0.0.1). You can use the web configuration to change this or by editing the setup.xml (see next paragraph).
Password and user default to "admin" and "admin" (without the "). All settings are saved in the setup.xml of the DVBViewers (sections "WebUser" and "WebGeneral"). The language files are identical with the ones of the Webserver for DVBViewer and have to be placed into the "Language" folder of the DVBViewer.
The html-templates are NOT identical and should be left in the default folder ("svcweb").
Plugins:
The Webinterface Plugin has been integrated into the service directly. On an Update install please uninstall the plugin by running unregplugs.bat from the COMPlugins folder.
Changes 1.4.0.0
- Uptodate with the current DVBViewer Pro release 3.9.2 (including AAC support and diseqc fixes).
- Integrated the Webinterface into the service.
- Fix: Sometimes the end action of a recording was not executed.
- Add: Non executeable timers are marked red in the webinterface.
- Changes: reworked details on the HTML Templates of the Webinterface.
#7 User is offline   Lars_MQ
  • Administrator
Posted 21 April 2008 - 11:34
Version 1.4.1 is in the Membersarea.
Changes:
- uptodate with the current DVBViewer Pro Beta (hardwarehandling etc.).
#8 User is offline   Lars_MQ
  • Administrator
Posted 12 May 2008 - 11:50
Version 1.4.1.7 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.1.7
  • Uptodate with the current DVBViewer Pro Beta release 3.9.3.50.
  • The user data (Username + Password) will from now on be stored in the userdata.xml file instead of the setup.xml, existing entries in the setup.xml will be removed.
  • The Webinterface can be disabled via the setup.xml: Section "[WebGeneral]", Value "Enabled" (1=activ, 0=disabled). Remember to stop the service before changing the setup.xml!
  • Optimized the Webpages. Details, Recording and IMDB removed. These functions now only can be reached via the detail window.
  • The Timerprogramming page is now a popup window. It can be disabled on the configuration page.
  • The Popup windows are now centered on the screen and will be brought to the foreground if needed. The are also bigger and have scrollbars now.
  • New pages: EPG Search. Search in the EPG with several userdefined criterias. (Hint: leaving the search phrase empty and selecting only a genre lists all entries for this genre (works not for all and none)).
  • Optimized: The Datageneration for the webpages has been highly optimzed/speedup and has now also a lower memory consumption.
#9 User is offline   Lars_MQ
  • Administrator
Posted 20 May 2008 - 19:33
Version 1.4.1.11 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.1.11
  • The Recording Service has it's own installer now. It's does all necessary for the Installation and registration of the service.
  • You can also do some basic configuring of the Weboptions in the Installer.
  • Reworked the right management issues. It should be possible now for non administrator users (and vista users with UAC) to start and stop the service.
  • Fix: The Webserver did not start after a standby.
  • Small optimizations of the webpages.
  • Updated the lng files (Thanks @gioxy).
in deutsch
#10 User is offline   Lars_MQ
  • Administrator
Posted 09 June 2008 - 10:48
Version 1.4.1.15 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.1.15
  • Add: ITV HD Fix for wrongly marked H264 video in the PMT.
  • Add: SimpleA/B DiseqC for NovaSPlus BDA cards.
  • Add: Guest Account for the Webinterface. You can activate and set the password on the configuration page of the webinterface. If security is disabled (empty admin password) the guest account does not work.
  • Add: Little Mobil/PDA Webinterface. Can be reached via http://[adress]/mobil/
  • Add: Webinterface: Recordings page.
  • Add: Webinterface: Timerpage: If EPG is available for a entry you can reach it by clicking the title of the timer.
  • Add: Webinterface: On the configuration page you can adjust the time interval for the "What's on today" page. 0 means don't use it (old behavior).
  • Add: Webinterface: In the templates for the pages Programs, EPG Search, What's on today and What's on now there are two new(old) tags: {recurl} and {subtitlelong}.
  • Update lng files.
in deutsch
#11 User is offline   Lars_MQ
  • Administrator
Posted 12 June 2008 - 12:56
Version 1.4.1.20 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.1.20
  • Fix: Several bugs in the html templates.
  • Remove: COM Plugins are not supported anymore.
  • Add: Limited DVBVIewer Plugin support:
    DVBViewer Plugins are NOT fully supported. Plugins, like the netstreaming plugin, using the dvb-stream can be used.
    Plugins like epg Plus or other plugins wanting to write/change data or try to show windows are not supported.
    The service exspects the plugins in a different folder structure to avoid complications with the DVBViewer.
    It uses
    DVBViewer Program folder\Plugins\Plugins1
    to
    DVBViewer Program folder\Plugins\Plugins32
    There is no need that all folders exists. But if you want to use them they have to be numbered seamlessly starting with 1. So you could do: Plugins1, Plugins2, Plugins3. This means only 3 recordings running at the same time(!) can use plugins, the rest will not use them.
    The service is recordings orientated, so each simultan recording gets an own PluginXX folder. So you have to be careful and only put one or two plugins per folder otherwise the systemload can get extremly high!
    Hint: If you use the netstreaming plugin remember to assign different ports to each one!
in deutsch
#12 User is offline   Lars_MQ
  • Administrator
Posted 28 June 2008 - 16:10
Version 1.4.1.23 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.1.23
  • Fix: Service didn't start up properly after hybrid-sleep on Vista (thanks @renzz).
  • New: Streaming of recordings via the web interface. You need an installed VLC (www.videolan.org) for it.
  • Update: language files updates.
  • New: The Webinterface supports chinese EPG.
  • New: Support for Hybrid tuners. You have to stop the service delete the hardware.xml in the userdata folder and restart the service. To force a new detection of the hybrid tuners. After that you can change your hardwaresettings with the dvbviewer as usual.
in deutsch
#13 User is offline   Lars_MQ
  • Administrator
Posted 12 July 2008 - 07:58
Version 1.4.2.0 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.2.0
  • Fix: The webinterface used a faulty header in some cases leading to a problem with safari.
  • Fix: Serveral critical preblems with standby and hibernate. Many thanks @Rolf Degen for restles testing and pointing out problems. :(
    Fixed: After wakeup from standby the pc went after a minute right into standby mode again.
    Fixed: If the pc was send to hibernate by the service it didn't wake up for the next recording.
  • Fix: The "Shutdown in" warning was only shown one time.
  • New: New menu item "Web Interface" in the trayutil popup menu.
  • New: Support for Terratec HTC.
in deutsch
#14 User is offline   Lars_MQ
  • Administrator
Posted 24 July 2008 - 13:38
Version 1.4.3.0 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.3.0
  • Fix: Trayutil: the autostart option was not marked even if it was active.
  • Fix: Trayutil: popup menu item webinterface was selectable even if the service was stopped.
  • New: LiveTV streaming. Uses either VLC for transcoding or a direct connection (like the netstreaming plugin - only useful for LAN).
  • New: basic Popcorn Hour support (LiveTV/Webinterface). Not all webpages work correctly at the moment.
  • New: Recordingservice can be run as a standalone application. Several tools will not work with it (commandline timerprogramming, TV Info) and coordination with the DVViewer doesn't work either.
  • New: Completely reworked "What's on today" page.
  • New: Several small enhancements of the webinterface.
  • Update: Language files updated.
in deutsch
#15 User is offline   Lars_MQ
  • Administrator
Posted 02 August 2008 - 21:00
Version 1.4.4.0 of the Recordingservice is in the Membersarea.
Quote
Changes 1.4.4.0
  • Fix: "New Timer" page did not show chinese channel names correctly.
  • Fix: "Edit Timer" page did mess up the selected channel.
  • Fix: The last version had to old versions of the Trayutil and Controller.
  • New: "Timer" Property page: the recording folder can be selected.
  • New: "Device Status" renamed to "Status".
  • New: "Status" page shows now more info.
  • New: "What's on today" page renamed to "TV Guide".
  • New: "What's now" page removed.
  • New: Added "Timeline" page.
  • New: The service can after Standby/Hybernate reset the DVB devices.
    Attention: the DVB device driver must support deactivate in the windows hardware manager.
    To enable it, you have to add to the apropriate section in the hardware.xml the following:
    <entry name="doReset">1</entry>
    Attention! Please test if this works for you before you use it!
  • Fix: Webadresses like http://[servername]/mobil now are handled correctly and don't cause a 404 error anymore.
  • Popcorn Hour Support:
  • Fix: PCs with more than one NIC are supported correctly now. The DVB Viewer should appear on the "sources" page of the Popcorn hour.
  • Fix: Every DVB-Server for the Popcorn Hour now gets an unique name, so you can have several DVB Servers in the sources display.
  • Fix: Crash on Config page fixed.
  • New: Specal HD (1280x720) templates are supported automatically. The templates are located in the "hd" folder. For now there is only a copy of the SDTV templates.
  • New: The number keys of the remote control act in LiveTV mode the same as in the DVBViewer. You can enter a channel number to switch the channel. No visual feedback possible for now. (Needs the Popi tool)
  • New: The Return key of the remote control acts as last channel key. (Needs the Popi tool).
in deutsch
Upcoming:
  • Tasks: perform tasks (execute applications or internal functions like epg update) based on a time table or events (resume from standby/hibernate, startup or manual via web interface).
  • Autosearch: Define search criterias for timer or reminder generation. Also usefull for series recordings.
  • Own confguration files. No dependence on the setup.xml anymore.
  • Usefull Popcorn Hour webinterface with real SDTV/HDTV templates.
  • Changed Channel management, everybody gets his/her personal channellist.
  • Per User/ per (hardware) client settings and rights.
  • Interface for XMLTV or other EPG data source import.
  • Methods for delvering all needed internal data to clients (xml Interface for EPG/Channels/Timers/Settings).
Share this topic:
  • (4 Pages)
  • 1
  • 2
  • 3
  • Last »
2 User(s) are reading this topic
0 members, 2 guests, 0 anonymous users
DVBViewer ShopGet RadLight Das Web 2.0 Download-Wiki-Portal DVBViewer FAQ
