In the Betasection of the
Membersarea is a new beta of the DVBViewer Pro.
This is a beta! So don't use it as a production system.
Installation:
You need a working DVBViewer Pro 3.9.4.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners.
Please post all reports to the
english or
deutsch beta forum.
The beta is meant
for users who are willing to improve the DVBViewer Pro by testing the below listed changes and reporting success or failure.
In case of FAILURE the report
MUST include
- the exact steps to reproduce the problem.
- the support.zip and other relevant data.
See also on top of the BETA threads in the DVBViewer Forum for further instructions.
Quote
Version BETA 3.9.4.99
expires 23.11.2008
- reactivated extensive debug logging.
- reactivated time limit.
- included latest DVBSource (3.3.0). Please use Filters\Register_Filters.exe to register it.
- Add: Added support for DVB Clock in the DVBViewer. For more information see DVBSource_3_3 ReadMe.rtf.
- Change: Timers: timers.xml is now saved on adding/deleting timers.
- Change: Rename Freeview EPG to FreeSAT EPG in MHW options.
- Change: Color/Brightness/Contrast window is only selectable if the driver reports that it can handle these settings.
- Change: Timeshift and recording folders are checked for sufficient rights on adding in the options.
- Change: Removed the save button in the recorder window. Update does save now the changes.
- Change: Recordings: added a check for rights in the recording folder. If no write rights are granted the default recording folder is used.
- Add: On format detection are several new data tags set:
#TV.video.pic
#TV.video.vres
#TV.video.hres
#TV.video.framerate
#TV.video.type
- Fix: Color/Brightness with INTEL graphics cards: fixed wrong default values for INTEL graphics cards. Thanks @Griga.
- Change: Toolbuttons: the toolbutton for the displaysettings now does show a submenu with the three possible choices.
- Add: Instant recording toolbutton. Implemented the instant recording popup menu for running instant recordings from the DVBViewer GE.
- Add: Hardware: support for Hauppauge DVB-C hybridcard.
- Add: Hardware: support for TEVII devices.
- Fix: DirectX options: Vmr fix and YUV didn't work correctly with Video B selection.
- Fix: USB CI: parental control PIN did not work.
- Add: CI: automatic parental control PIN (Jugendschutz PIN) entry. The PIN must be put into the userdata.xml:
<section name="CAM">
<entry name="PIN">1234</entry>
</section>
- Change: DVBSubtitles are now shown with the intended transparency.
- Change: DVB Subtitles: Thanks to griga the dvb subtitles now are shown "just in time" instead of "sometimes". You need the DVB Source 3.3.0 for it.
If you encounter problems, please report these with a short recording (including dvbsubs) of the problematic station!
- Add: Support for EAC3 (you need the current 3.3.0 DVBSource and a fitting audiodecoder). For more information see DVBSource_3_3 ReadMe.rtf.
- Fix: LastFM skip does work now.
- Change: OSD Timeline: OSD-OK on a program entry now shows the details of the program.
- Updated language files.
- Several fixes and enhancements.
Please post all reports to the english or deutsch beta forum.
