Transponder Update
Annunaki
Transponder Updates
  • UK - Winter Hill (North West Region) - All Digital Free 2 Air services are now availible. - Download Link: DVBT_UK_Winter_Hill.ini
Instructions for Transponder File Update
  1.
  2. Exit DVBViewer program.
  3. Navigate to program folder location: "C:\Program Files\DVBViewer" or where you have actually installed DVBViewer.
  4. Open up the Transponder Folder and then copy the attached .ini file from this thread into this folder.
  5. Load DVBViewer and then navigate to Help/Configuration folder.
  6. Again open up the Transponder Folder and then copy the attached .ini file from this thread into this folder.
  7. Exit and Reload DVBViewer program.
  8. Navigate to Channel/Channel scan.
  9. In the Transponder drop down list box select the new transponder from the list.
  10. Click the scan range button to begin scanning.
Edited by Annunaki
Link to comment
