Astra 28° East Changes
Griga
Due to the recent Eutelsat 28A -> Astra 1N/2A/2F changeover a lot of UK channels have moved to other frequencies resp. transponders with different parametes.
You may use the attached up-to-date transponder list Astra 28E.ini for scanning. Store it in the configuration folder\transponders subdirectory. It will appear as "Astra 28.2°E" in the DVBViewer Scanner Window or TransEdit.
Or import the Astra_28E_FTA_Channels.ini channellist in DVBViewer. Delete your old Astra 28° East channels resp. root folder, drag and drop the file into the DVBViewer channellist editor and adjust DiSEqC according to your needs if required.
Astra 28E Transponders & Channels.zip
Edited by Griga
Attachment updated
  • Like 1
Link to comment
I've updated the channel and transponder list in the first post.
Several transponders have been switched off in the meantime, which made a lot of double entries vanish from the channellist, as far as I can see.
Link to comment
