7abib0 Posted April 20, 2014 Share Posted April 20, 2014 Hello, I'm newbie here and I need your help to streaming from DVBViewer to iPad on iOS 7.0.6. Here what I did so far but without success. --- On PC: - Downloaded iOS Webinterface (iOS 7 only! - I copied "Language" folder into "C:\Program Files (x86)\DVBViewer" - I copied "iOS_713" folder into "C:\Program Files (x86)\DVBViewer\SVCweb" On DVBViewer: Netstream plugin settings: Active Unicast Interface: 192.168.15.219 max. Users: 1 (tried also 2) Port: 2345 Buffercount: 100 On iPad: - I opened Safari and navigated to http://192.168.15.219:2345/iOS_713 Nothing happened! --- Waiting your suggestions .. Link to comment
hdv Posted April 20, 2014 Share Posted April 20, 2014 the NetStreaming Plugin is outdated. install anduse the Recording Service http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Link to comment
7abib0 Posted April 20, 2014 Author Share Posted April 20, 2014 Ok I installed Recording Service with FFmpeg. Do I have now to disable NetStreaming Plugin? What I have to do with Recording Service settings so I be able to streaming to iPad. I'm not very good on this, be passion with me Link to comment
7abib0 Posted April 21, 2014 Author Share Posted April 21, 2014 I just want to stream the current channel on DVB to the iPad. That's my simple question. Link to comment
7abib0 Posted April 22, 2014 Author Share Posted April 22, 2014 Finally I can access DVBViewer from iPad. But still have problems. - I want the current playing channel in DVBViewer to be streaming on iPad. - On iPad when I watch Live TV it works for a seconds then stop. - How to stream to VLC over netwrok? Link to comment
7abib0 Posted April 24, 2014 Author Share Posted April 24, 2014 Ok I solved All my problems. Thank you for your helps Link to comment
papaschlumpf Posted May 18, 2014 Share Posted May 18, 2014 Hello 7abib0, May you please write down what i need to do. Which app and which link do you use? Link to comment
