Fulco Posted June 21, 2016 Share Posted June 21, 2016 Hi All, I am currently replacing my Satellite PC (Windows 10 Pro x64, 3 Sats with Spaun Multiswitch) I tested the system with a Digital Devices “Cine S2 V6.5” Everything worked fine. So bought a Digital Devices “8 Tuner TV Card - Full Spectrum - DD Max S8 (4/8) TV Card”. With the DD Max S8 (DDControl set to: "Quad LNB or 4 Multiswitch output") however the DiSeqC doesn't seem to work. Only the satellite on posA/OptA is working OK. Maybe this card doesn't support DiSeqC, it isn't mentioned in the specs? Fulco support.zip Quote Link to comment
Fulco Posted June 22, 2016 Author Share Posted June 22, 2016 I found this on the internet: S8 max card does not support Disecq. It's a full spectrum card.... Connecting directly to lnb works perfectly. So for others planning to use this card, only buy it if you stick to one satellite or have unicable 2 system. Conclusion: not the right card for more then one satellite. Fulco Quote Link to comment
