Honzik1
PCTV 290e - DVB-T2 Problem
Honzik1
Hey,
DVB-T2 started in Czech few months ago. I can tune here old DVB-T muxes well with 100% signal strenght and 100% quality but DVB-T2 mux 28 is with 100% signal too but only 60% quality and many discontinuities (There are often errors in the picture) What could be the problem? My location is in city Pardubice between 2 transmitters (one 70km, and another 20km) and both are transmitting DVB-T2 on same mux 28, could it be problem? Is transmitting on same mux 28 from 2 transmitters problem for Sony CXD2820R chip? I am receiving channels from 70km transmitter in Trutnov - Cerna hora and I think anthena is partly catching mux 28 (DVB-T2) from 20km away transmitter too.
Thank you for the answer!
Jan - Czech Republic
EDIT: I just tested weak room anthena which surely catch signal just from 20km transmitter on mux28 and problem is same. I can tune without picture lose DVB-T1 channel but not DVB-T2 channels. It has discontinuities like each 5 seconds like on picture below.
Edited by Honzik1
Share this post
Link to post
bogdan1980
in dvb source i haved set by default clock selection to audio clock, maybe this help.
Share this post
Link to post
Honzik1
It have not helped. Seems like receiving DVB-T2 signal cause problems in other DVB software too. Not sure where can be problem.
Edited by Honzik1
Share this post
Link to post
Derrick
It could have other reasons..
The DVB-T2 modulation is more robust than DVB-T. With similar modulation parameters and radiation power the Quality should be higher not lower. But the more effective modulation normally is used to output a much higher transmission rate which in fact results in a quality deterioration. Please check with Transedit's analyzer the data rate (lower right corner) of old and new muxes.
Share this post
Link to post
Honzik1
23 hours ago, Griga said:
The PCTV 290e doesn't work with German DVB-T2 either due to a demodulator chip that is not suitable for DVB-T2 version V1.3.1. See here
http://www.DVBViewer.tv/forum/topic/58320-pctv-nanostick-t2-dekodiert-nicht-dvb-t2/?do=findComment&comment=447565
Try to find out which DVB-T2 version is used in Czech.
I found this document in Czech language about our DVB-T2:
http://www.rticz.com/files/D-book_2016_v4-03.pdf
DVB-T2 version is ETSI TS 102 831 (2012) which should be V1.2.1 (because v1.3.1 should be ETSI TS 102 773  if I googled right). PCTV 290e could be capable of v1.2.1 right?
I am sending screenshots from transedit. All muxes are 70km far from me.
1) mux 21, DVB-T1, transmitter only 20kW (no problems with audio/video)
2) mux 28, DVB-T2, transmitter 100kW (problem with video every 3-5 seconds, sometimes with audio)
3) mux 40, DVB-T1, transmitter 100kW(no problems with audio/video)
As I said, there is another transmitter 20km away transmitting DVB-T2 too on 28 mux same as 70km far transmitter which I am using. Could it be a problem?
Any idea why there are many rows with question mark "?" in stream type column?
I coudnt upload images here, because some strange upload limit 10kb...., so here are links:
https://postimg.org/image/qo2nhnqrn/
https://postimg.org/image/xraixa3wz/
https://postimg.org/image/ytkpft7ar/
Edited by Honzik1
Share this post
Link to post
Honzik1
Any idea where could be a problem?
Share this post
Link to post
INGBEAN
Hello Honzik1!
Please post a support.zip because I need more information of your system.
Best regards!
INGBEAN
Share this post
Link to post
Honzik1
9 hours ago, INGBEAN said:
Hello Honzik1!
Best regards!
INGBEAN
I cannot upload support.zip here because some strange upload limit 10.24kB, can you fix it please?
Here is external link:
https://ufile.io/afikh
Thanks for support!
Share this post
Link to post
INGBEAN
vor 4 Stunden schrieb Honzik1:
The summary of your attachments is limited to 1MB.
You can delete old attachments here if you have not enough attachment space.
I don't find the PCTV driver version in support.zip.
Please look into "device manager" and post installed driver version of your PCTV 290e USB-stick.
INGBEAN
Share this post
Link to post
Honzik1
INGBEAN
OK, I get it. Cannot you just increase that 1MB attachment limit? 1 MB is pretty low for screenshots etc. My previous posts will now miss screenshots which described the problem? For reference at historical posts would be nice to keep attachment there.
I actually use latest driver for PCTV 290e I have found on google which is DriverVer = 03/26/2015, 5.2015.0326.0
Latest PCTV 290e driver I found on PCTV FTP server was DriverVer = 12/06/2013, 5.2013.1206.0
And driver downloaded directly from PCTV website is DriverVer = 09/01/2010, 5.2010.0901.0
All drivers behave same and problem with DVB-T2 is always there. Just with driver 2010 there appear 2 devices in HW list: DVB-T device and DVB-C device. 2013 and 2015 driver shows just DVB-T device in hardware list.
Any idea where could be the problem with DVB-T2  forr PCTV 290e? I do not want to buy new DVB-T2 USB tunner and then find out that problem is still there. Or is there chance to find out if problem is in 290e or at bad signal? Neighbours says that DVB-T2 work without picture issues to them.....
Thanks much for the answer
Share this post
Link to post
INGBEAN
vor 20 Stunden schrieb Honzik1:
Cann you just increase that 1MB attachment limit?
No.
I didn't know that there is an existing driver of 2015. Thanks for information.
You can contact PCTV support team - see http://www.pctvsystems.com/Support/Supportcontact/tabid/233/language/en-US/Default.aspx -> maybe they have already released an updated driver for PCTV 290e?
By the way: did you always clicked "Scan Devices" in "Options -> Hardware" at DVBViewer each time after installing new driver (and "Detect Devices" in TransEdit")?
Do you have a chance to test your system with antenna of your neighbours?
Do you use a passive or active indoor antenna? I don't know the receiving situation on your site, but maybe an outdoor or roof antenna is the better choice?
Your target is: Get the number 0 in "Missing" column of TransEdit!
I don't know, if your CPU i5-4670K with NVIDIA GeForce GTX 770 is powerful enough for PC to decode HVEC codec.
This question goes  to DVB-T2 users in Germany...
Best regards from Austria!
INGBEAN
Share this post
Link to post
Honzik1
Yes.
I live in apartment house with shared anthena which is on roof, so I should have same quality and signal strength as my neighbours.
Yeah I know.
I have tested 4K H265 video and my PC can handle it with like 50-60 CPU usage since GTX 770 has not native HEVC hardware support.
I will try to ask PCTV directly but I dont give it much chance.
Do you have good experience with any of these USB DVB-T2 sticks?
https://www.linuxtv.org/wiki/index.php/DVB-T2_USB_Devices
I have found that Geniatech T230 and Astrometa DVB-T2 are available at Aliexpress.
Thanks!
Share this post
Link to post
INGBEAN
Hello Honzik1!
Here in Austria I have very good experience with DVBSky T330 USB-stick.
I recommend to buy it at this distributor, because you get an excellence support and they have a DIRECT contact to manufacturer (for driver updates):
http://www.bettershopping.eu/de_CZ/shop/PC_Hardware/TV_Karten_Boxen/DVB-C_Kabel/ART02388_DVBSky_USB_DVB-C_T_T2_FTA_T330_CD.html
or
https://www.amazon.de/DVBSky-Empfänger-Raspberry-Erweiterungstuner-Receiver/dp/B072FP1TX4/ref=sr_1_1?ie=UTF8&keywords=dvbsky t330&language=cs_CZ&qid=1515089869&sr=8-1
Best regards!
INGBEAN
Share this post
Link to post
Honzik1
12 hours ago, INGBEAN said:
Hello Honzik1!
or
Best regards!
INGBEAN
I found it in Czech republic too, but it is 3-4x more expensive than Geniatech T230 and Astrometa DVB-T2 here. Are there some problems with these cheaper DVB-T2 USB sticks?
Thanks!
Share this post
Link to post
INGBEAN
Hello Honzik1!
Sorry for late reply, but a friend of me has a Geniatech T230 and I wanted to integrate his information to my post.
Well, we have 2 problems in relation to DVB-T2.
Problem 1: DVB-T2 standard has a lot of configuration options.
So broadcasting companies of different countries are using various settings.
Problem 2: You never know which chipset (tuner & demodulator) is installed in your USB-stick.
I have here two identical USB-stick chassis of same manufacturer - but the chips on board are different.
In combination with "problem 1" you have various behavior in different countries. :disgust:
According upper problem descriptions, a manufacturer support is very helpful.
That's why I recommend to use the DVBSky T330, which works perfectly in Austria and Germany.
To be honest: 40 Euro is not really expensive, if you get a reception sensitive product with good support.
If you buy a cheap product and run into troubles, you invest a lot of time and angriness to find a solution!
My friend has a Geniatech T230 and it does NOT work as expected here in Austria. :wacko:
Best regards!
INGBEAN
Share this post
Link to post
Honzik1
19 hours ago, INGBEAN said:
Hello Honzik1!
Best regards!
INGBEAN
In Czech there is probably no official distribution of T330. It cost 65-70 Eur here. About T230 - what do you mean exactly by "it does NOT work as expected"?
What chip does DVBSKy T330 use? T230 should use Silicon Labs Si2148 by this site: https://www.linuxtv.org/wiki/index.php/DVB-T2_USB_Devices
Edited by Honzik1
Silicon Labs Si2148
Share this post
Link to post
INGBEAN
Am ‎11‎.‎01‎.‎2018 um 08:47 schrieb Honzik1:
According my friend, DVB-T2 reception of T230 in Austria is only possible with CrazyScan2, NOT with DVBViewer.
But in Croatia it works with DVBViewer fine.
The root cause is a buggy Geniatech driver in combination with used DVB-T2 settings of austrian broadcasting company.
Maybe T230 stick works in Czech? Just test it on your site.
Other forum readers would be very happy to get your feedback.
INGBEAN
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Similar Content
    • wolfgang@uwkurz.de
      By wolfgang@uwkurz.de
      Liebe Teammitglieder,  sehr geehrter Herr Hackbarth,
      ich habe Nero 2018 erworben, um mit DVBViewer aufgenommene Videos zu bearbeiten.
      (z.B. um Anfang und Ende korrekt zu setzen).
      Bei den DVB-T2 .ts Dateien bekomme ich zwar das Bild, aber keinen Ton.
      Der Nero Kundendienst hat mir nun folgendes geschrieben (siehe weiter unten).
      Frage: Wie kann ich nun im DVBViewer einen der von Nero unterstütztem Audio Codecs einstellen.
      Welcher Audio Codec ist zu empfehlen ?
      Vorhanden in meinem System sind:
      LPC Hub Controller 1 : ASRock FCH LPC Bridge
      Audio Gerät : MSI High Definition Audio Bus
      Audio Codec : AMD HDMI Audio
      Audio Gerät : ASRock High Definition Audio-Controller
      Audio Codec : Realtek Semi 1220
      Viele Dank.
      Wolfgang
      Antwort des NERO Kundendienstes
      Kundendienst [2017-10-25 11:47:26.477]
      Sehr geehrter Herr Kurz,
      Wir müssen Sie leider darüber in Kenntnis setzen, dass Nero aufgrund verschiedener technischer und rechtlicher Unwägbarkeiten, nicht mehr in der Lage ist, das Abspielen von HD-Audio zu ermöglichen, welches in den meisten DVB T2 Übertragungen genutzt wird. Wir betonen, dass wir uns diese Entscheidung nicht leicht gemacht haben, und es uns sehr Leid tut, unsere treuen Kunden enttäuschen zu müssen.
      Wir möchten uns für die Ihnen entstandenen Unannehmlichkeiten entschuldigen.
      Eine Möglichkeit, wäre das direkte Aufnehmen in einem anderen Audio Codec mit Ihrer Aufnahmesoftware.
      Folgende Audio Codecs werden unterstützt:
          Advanced Audio Coding (AAC)-Elementarstream – kein Kopieren
          MPEG High-Definition AAC (HD-AAC)
          Moving Picture Experts Group Audio Layer 3 (MP3/mp3PRO/mp3HD)
          MPEG-4 Audio (MP4, M4A)
          MPEG Audio (MP2, MP2A, MPA, MPA2, M2A)
          Dolby® Digital (AC3)
          Audio Interchange File Format (AIFF, AIF)
          Compact Disc Digital Audio (CDA) – keine Kodierung
          Ogg Vorbis (OGG, OGM, OGA)
          PCM WAV Datei, ADPCM Wave Datei (WAV, WAVE)
          Windows Media™ Audio (WMA)
          Free Lossless Audio Codec (FLAC)
          Monkey’s Audio (APE)
          Matroska Audio (MKA)
      Wenn Sie weitere Fragen oder Anmerkungen zu unseren Produkten haben, können Sie uns gerne jederzeit wieder kontaktieren.
      Mit freundlichen Grüßen,
      Norman Reinköster
      Nero Support
      Kundendienst [2017-10-25 10:40:42.273]
      Frage: Wie kann ich in Nero 2018 Platinum DVB-T2 Dateine bearbeiten.
      Wie Sie sicher wissen, gibt es in Dweutschlöand seit Frühjahr dieses Jahres (2018) kein DVB-T mehr, sondern nur noch DVB-T2.
      Ich besitze zwei VideoKarten (TerraTec Cynergy T2 Stick BDA Device und TerraTec Cynergy T2 Stick micro BDA)
      Werden diese Karten in näherer Zukunft unterstützt und können mit diesem Karten (z.B. mit DVBViewer) aufgenommenen Vidoeas mit Nero nachbearbeitet werden - z. B. am Anfang und Ende beschnitten werden.
      Im Moment wird zwar das Video Bild angezeigt, es fehlt aber de zugehörige Ton völlig.
      Wie kann das behoben werden.
      OHen DVB-T2 Unterstützuund ist Nero 2018 Video für mich nutzlos.
      MfG
      Wolfgang Kurz
    • SchauAN
      By SchauAN
      Von Microsoft ist eine Erweiterung für HEVC-Videos verfügbar, die auch von anderen Anwendungen genutzt werden kann. Vielleicht eine weitere Möglichkeit, HEVC DVB-T2 im DVBViewer mit Hardwareunterstützung, also minimaler Systemlast, abzuspielen.
    • Peterchen9
      By Peterchen9
      die Wiedergabe von Live-TV erfolgt nur in "Zeitlupe". Das Bild ist erheblich verlangsamt, der Ton wir immer asynchroner. Dies tritt erst seit der Umstellung auf DVB-T2 nebst Tausch des DVB-T-Sticks und der Software (vorher eine Terretac-Variante von DVBViewer) auf. Davor lief alles einwandfrei.
      Die Daten:
      HP 635 Laptop Win10/64 TV-Stick: HMP-Combo DVB C/T2 Hybrid USB TUNER Support.zip ist im Anhang.
      Full-HD-Videos spielt der Rechner problemlos ab. Zu langsam sollte er also nicht sein.
      Hat jemand einen Tipp?
    • gleddamax
      By gleddamax
      Hallo zusammen,
      wenn ich mich recht entsinne wurde während des DVB-T2 Testbetriebs der Ton bei den ZDF-Sendern nur mit DD 2.0 ausgestrahlt. Seit der Umstellung kann ich bei mir bei Live-TV und in Aufnahmen mit DD5.1-Ton kleine Tonstörungen ausmachen, die sich für mich wie kleine Knackser anhören oder als ob sich irgendwas "verschluckt". Erinnert mich beim Anhören irgendwie an Clippingschutz, bei dem die Zeitspanne der Lautstärkeänderungen auf einen Bruchteil einer Sekunde zusammengestaucht ist.
      Ausprobiert habe ich AC3-Decoder von LAVFilter, Hauppauge, Arcsoft, AC3Filter, Microsoft - Besserung oder gar Abhilfe brachte keiner.
      Habe heute zwei kurze Beispielvideos (~15MB & ~18MB) aufgenommen und hier hochgeladen, vorherige Aufnahmen habe ich in der zwischenzeit leider schon gelöscht, nachdem mir das Problem bei der Durchsicht der Aufnahmen erst bewusst wurde. Bei den ARD-Sendern habe ich keine Auffälligkeiten bemerkt, da läuft der Ton sauber auch in den Aufnahmen.
      Liegt es an meinem Rechner oder gibt es noch jemanden mit diesem Phänomen? Zumindest konnte ich weder Lastspitzen, vollen RAM oder Discontinuities in DVB Source feststellen. Der Videoanteil ist sonst einwandfrei; keine Klötzchenbildung oder Artefakte.
      Support.zip habe ich angehängt. Der DVB-Stick hängt zwar an einem USB 3.0-Hub, aber ein Umstecken an einen USB-2.0-Port direkt am PC bringt auch keine Besserung. Bin mittlerweile auf die DVBViewer Version 6 umgestiegen, bei der vorigen Verison 5.6.4 traten die Tonstörungen genauso auf.
      Gruß,
          gleddamax
    • SchauAN
      By SchauAN
      Das DVB-T2 Live-Bild hat nur im Vollbild am linken Rand einen Störungskeil aus Klötzchenbildung, der nach unten größer wird bis ca. zum 11. Lautstärkebalken, der flackert. Es ist nicht immer gleich auffällig, bei sehr ruhigen Szenen ist es nicht zu sehen. Dieses Problem tritt nur im Vollbild und nur Live auf. Die gleiche Szene aus der Aufnahme zeigt nur einen flackernden Lautstärkebalken.
      Im Bild sind zwei von links-oben nach rechts-unten verlaufende Treppen zu sehen. Auch hier nur bei Live-Bildern und auch hier nicht immer. Unten die Fotos davon.
      Ich verwende die LAV-Filter 0.69.0.16-git (arte-Fix), aber auch die Version davor zeigte das Problem. Die Prozessorlast liegt im gesamten System bei max. 20%, üblich bei 8%.
      Timingfehler?
      support pro.zip
