Search the Community
Showing results for tags 'multiple tuners plugins deleg'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. Hi there, I'm somewhat confused about my setup of: - Quad Tuner card(TBS6985, only 2 tuners in use) - Two Twin Output LNB's connected directly to the tuner card(1 from each LNB) - DVBViewer Recording Server on my server - 2 clients on my two laptops using RS on the server My questions are: 1) I need to scan channels on Tuner A in Channel Group A and Tuner B in Channel group B in order to make DVBViewer aware of "this channel on Tuner A and other channel on Tuner B"? 2) What are the relationship between Plugins1, Plugins2, PluginsX in the Plugins folder - is Plugin1 used on Tuner 1 and Plugins2 used on Tuner2, etc.? 3) Do I need to setup two Unicast devices on my clients(Channel Group A and Channel Group B - as channels are ordered in RS on the server)? My confusion is this: I can see that no matter how many Tuner's I use(only 2 at the moment), only plugins in Plugins2 is activated(used), no matter how many Clients I connect to RS on the server, only plugins in Plugins2 are activated/used - so what's the relationship between the Plugins folders and tuners/clients/other?
