Search the Community
Showing results for tags 'not decoding black screen'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. One channel can no longer be seen. Started approximately one month ago - maybe after an update of DVBViewer og HDHomerun firmware. A BLACK screen with correct EPG info is shown after selecting the channel. Other full HD channels still works Checking the DVB Source properties (attatched) shows: Video State: No data / Connected, PID 1200 Audio State: No data / Connected, PID 1200 this is clearly not good. Tried: - retune on HDHomerun (but no problem using the HDHomerun viewer) - rescan on DVBViewer (both using the recording service and DVBViewer directly) - reinstall DVBViewer - Recording the problem channel using Recording services, but recording disapperes (from list and file) AFTER timer being closed (maybe due to 0 size?) Installing DVBViewer give a warning about the "HEVC Video Decoder". I did select the LAV decoders to be installed and think that this warning then disappeared (is LAV a HEVC decoder?) What should be done next ? / Poul Attatched: - support.zip - DVB Source properties - Channel List - info for channel Environment: - WIN7 64 bit - running 32 bit DVBViewer (no 64 bit version installed) - Tuner - HDHomeRun EXPAND - 4 cable tuners - Firmware: 20150826 - Provider: Denmark / YouSee Failing Channel - TV2HD (DK YouSee) The channel can be viewed using the HDHomeRun viewer. support.zip
