Hi
Using DVBViewer latest version, a BGT3600 dual DVB-T, Dual DVB-S tuner card and recording service set to unicast over a wired network.
I get lip sync issues with an OPPO-103D Blue ray player set as a DNLA renderer when sending either TS or MPEG to the renderer.
The problem I'm seeing is that the OPPO103 seems to need one value of lipsync delay when playing SD TV and a differnent value (much more audio delay) when playing HD material - certainly when acting as a live stream renderer.
Just so I can rule out DVBViewer in this - Am I correct in assuming that DVBViewer cannot possibly be causing lipsync issues as its recording service is simply sending received packets over the LAN and that nothing it does could change the realationship between sound and vision as these are locked togther inside the transmitted packet and are as transmitted by the TV company etc.?
I need to rule this out before appoaching OPPO with a bug report.
Currently use of OPPO as a DNLA renderer is hopeless due to this issue.
K
