Search the Community
Showing results for tags 'pid filter'.
Hi, After a lot of time requesting the Streaming button in the TransEdit tool, finally the last version 4.2.1 has it! THANK YOU! :-) http://www.DVBViewer.tv/forum/topic/56627-streaming-button-in-transedit/ Now, I have another suggestion. If you use SAT>IP servers as your tuners, you know for sure that a lot of servers doesn't support the Full Transport streaming. Yes, almost all support "pids=all", and this it's great. However, when the TS has a high bandwidth, or it goes over a specific bitrate, in this case the resulting RTP streaming has a lot of Continuity Errors. This, isn't a problem for the internal Analyzer of the TransEdit, as the PSI tables can be readed multiple times. However, if you like to do an streaming, this can be a problem. So, here it's my suggestion: At time, when you select with the mouse multiple pids in the Analyzer and you start the streaming (CTRL+S), then you're sending only the selected pids. And this it's great! Thank you! However, the TransEdit are in fact receving the full TS. So the filtering it's internal. But, if you include in the configuration some option, it should be possible to request to the tuner to only send the selected pids. And when the streaming stops, or some change occurs in the pid list, then update the list (and when no streaming, then restablish the "pids=all"). This will be a must have for SAT>IP servers! With this any external tool can be used for TS analysis, using the TransEdit as a TUNER. Please, consider it. Regards.
