Search the Community
Showing results for tags 'recorded tv'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 2 results
  1. I've recently installed the latest version of DVBViewer, but when I try to play old mpg recordings (recorder with a very old version of DVBViewer) most of them freezes; on the ones that don't freeze is not possible to jump forward or back. I've noticed that I have not the same problem with .ts files (old and new) nor with mpg recordings made with current version of the program. I have tried playing a bit with codecs but I can't see any improvements (now I'm using ffdshow codec). Any idea?
  2. Hi, I've been using DVBViewer for a while now and pretty pleased with the software and how reliable it all is. Im using a mixture of satellite and terrestrial for FTA TV. Now i have the TV side of things up and running nicely i want to move onto the next part of my HTPC project / setup - Has anyone managed to record FTA TV Shows, remove commercials and load the into a TV series library database? If so could you give me a few pointers? This would be the ultimate HTPC setup for me as there are loads of shows i enjoy watching and recording! Thanks.
