Search the Community
Showing results for tags 'recording errors log'.
Hi I've been using DVBViewer for quite some time now. Until about a year ago, it worked very good. But then I started getting errors like: 20:20:24 / 00:00:22 (~ 25,61 MB) Errors: 3 20:20:31 / 00:00:28 (~ 32,62 MB) Errors: 5 20:20:55 / 00:00:52 (~ 60,86 MB) Errors: 3 in the log-file. Not very important, as it was only 20-50 error pr hour. But the number of errors have been constantly increasing, and now it is 700-800 errors pr hour. The very big problem now, is that the program I use to cut the recording clean, ie. the first 10 minutes and the last 30 minutes, giving a file with exactly the size of the recording, cannot be used with such a large number of errors. Also, I can see, that even if it does work, a lot of small parts of the recording (both sound and frames) are missing. I have tried to record on two different computers, with two different kind of hardware (an inbuilt Cynergy-card and an HDHomeRun) but the errors are still there. I have had a visit by a technician from my cable-TV provider, and he checked every single part from outside the building to the computer or HDHomeRun, and found no cable or connection problems. So, if the TV-signal is OK (and my "normal" TV plays absolutely fine) and I have the same errors on two different computers with two different tuners, I think it can only be the software. I have surfed here and there to see if other have had the problems, but so far with no luck. I hope someone in this forum can help me, as it probably just is a configuration problem? Or if anyone have seen a solution anywhere, please let me know I have attached a logfile with all the errors from one recording Thank you in advance :-) 2016-04-23_22-30-01_DR 1_Lewis - Krimiserie. Fem år efter kriminalkommissær Morses.log
