Search the Community
Showing results for tags 'rs 1.33'.
Good day, when is enabled "Adjust PAT/PMT" and in recording log is "Channel update tcPMT tcVideo tcAudio tcVideotext tcPCR" then PAT/PMT is in ts file wrong. Log of recording: CT 2 26.6.2016 W:\For The Record\2016-06-26 (2009); Život na Zemi Primáti.ts Device: TERRATEC T5 Rev.2 Tuner 1 (7) EventID: 4768 Timer Name: Život na Zemi: Primáti Timer Start: 26.6.2016 17:05:00 Timer Duration: 1:30:00 (90 min. incl. 20 min. lead time, 20 min. follow-up time) Timer Options: Teletext=1, DVB Subtitles=1, All Audio Tracks=1, Adjust PAT/PMT=1, EIT EPG Data=1, Transponder Dump=0 Timer Source: Search:Život na zemi 17:05:02 / 0:00:00 (~ 0,00 MB) Start Recording 17:05:02 Channel update tcPMT tcVideo tcAudio tcVideotext tcPCR 17:05:03 / 0:00:01 (~ 0,00 MB) Život na Zemi: Primáti not running | EventID: 4768 PDC: 0x00000 17:05:04 / 0:00:01 (~ 0,98 MB) PID 1365: MPEG Audio Stereo, 48 khz, 192 kbps 17:05:04 / 0:00:01 (~ 0,98 MB) PID 1366: MPEG Audio Mono, 48 khz, 64 kbps 17:05:04 / 0:00:01 (~ 0,98 MB) PID 1364: MPEG2 Video, 16:9, 720x576, 25 fps 17:05:05 / 0:00:02 (~ 1,55 MB) Až na kraj světa: Poslední stopa Butche a Sundance running | EventID: 4769 PDC: 0x00000 17:24:58 / 0:19:56 (~ 616,88 MB) Život na Zemi: Primáti running | EventID: 4768 PDC: 0x00000 17:25:00 / 0:19:57 (~ 617,65 MB) Krajinou domova (8. díl) not running | EventID: 4767 PDC: 0x00000 18:14:58 / 1:09:56 (~ 2075,09 MB) Krajinou domova (8. díl) running | EventID: 4767 PDC: 0x00000 18:15:00 / 1:09:58 (~ 2075,70 MB) Večerníček not running | EventID: 4766 PDC: 0x00000 18:35:00 / 1:29:58 (~ 2664,52 MB) Stop Average Data Rate: 0,494 MB/s Total Size: 2664,5 MB (2793952788 Bytes) -------------------------------------------------------------------------- First 100 MB of recording (raw cutted with TS Doctor) you can download from here: https://ulozto.cz/!p2MaQCKVd/new-cutted-ts
