Search the Community
Showing results for tags 'signal lost restart rescan'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. Hallo, Now Im trying Demo because considering buying full version. DVBViewer works fine. But after restart my PC - an error occurred. It looks like DVBViewer lost DVB-T signal. Signal is very low => all channels fluctuate between 0 and 20%, no any picture. I must rescan channels ("scan frequency" or "scan range") then all channels work fine again, signal is for 100%. The second option is: I must turn on and turn of my primary TV software (DVBDream). Then DVBViewer works without channels rescan. I tried: - Checked my DVB-T antena and cables (no problem) - Checked last drivers for my TV card - Updated VGA drivers, DirectX, audio drivers, codecs and OS via Windows update - Export and after PC restart import channel list from *.ini file (still same error) - Reinstalled operating system (clear new installation without others TV and multimedia software) - Others TV programs (for ex. DVBDream) work correctly I have: - Windows7 Ultimate 64bit (My friend uses DVBViewer /I dont know version/ with same TV card on Windows XP 32bit without problems) - Pinnacle TV card 710iX PCIe (only for DVB-T) but into DVBViewer is designated like Pinnacle 3010ix (as well as in DVBDream) - nVidia GeForce 8600GT - C2D 3,6GHz and 4GB RAM Where is the problem? It is a demo feature? Thanks.
