Search the Community
Showing results for tags 'tv source'.
Dvbviewer and NAS + Tv tuner ^ Dvblink Tv server
soundguy posted a topic in General DVBViewer Pro/GE
Hello, i am newbie.. i have this HW: Netgear Readynas 312 2.1ghz atom, 4gb ram along with Evolveo Venus - dual usb stick tv tuner with software DVBLINK TV SERVER, that is linux based app for NAS servers allowing record and stream videos from tv tuner When i play streams on my PC from NAS using Windows Media Player, it works ok. Also using Media Player Classic works flawless. But in DVBViewer i am having big difficulties. In my opinion there is something with Mpeg 2 demuxer or Mpeg 2 decoders, ... i dont know.. because twice happened, that i have seen working video along with sound in DVBViewer, but that didnt happened more again. (Tv signal source is ok.) urls come in this shape (contained in m3u files): http://192.168.1.4:8101/dvblink/direct?client=f4a4da4c188b334abac55d9e0ff99bcd&channel=10530000 http://192.168.1.4:8101/dvblink/direct?client=f4a4da4c188b334abac55d9e0ff99bcd&channel=10540000 http://192.168.1.4:8101/dvblink/direct?client=f4a4da4c188b334abac55d9e0ff99bcd&channel=10550000 or in this shape: http://192.168.1.4:49153/TVChannels/10530000 http://192.168.1.4:49153/TVChannels/10540000 http://192.168.1.4:49153/TVChannels/10550000 neither work (in DVBViewer). Altought NAS side Dvblink monitoring shows, that stream is being encoded correctly with bitrate and also channel changes there, if i change url or stream in DVBViewer. Just no video and audio appears inside it (except the 2 or 3 cases described above)... I have spent about 4 hours trying to find a solution.. I am complete newbie, i was also trying to add a hardware inside DVBViewer, that maybe should not be necesarry. But also i didnt succeeded. Altought i know, i can add normal playlist along with URLs. I thought it could get load some net stream or etc, but i dont know if this DVBlink TV server produces. This should be only DVBViewer problem, as WMP and MPC:HC are working correctly. Thanks for any help i have not much possible settings in DvbLink TV server, it only shows: PORT for administration 39876 along with PORT for broadcast 8100. I have put these credentials into "imaginational" tv tuners like dvb-IP-tv but with no succes, because i m noob. EDIT: if i open UPNP, DVBLINK DLNA SERVER, i can browser tv channels, urls are in the second shape (quoted in text above), but when i load them into DVBViewer, it says "playing" but with no audio or video showing. i have also deleted user folder of DVBViewer to prevent any mess and start from scratch.. no success. Altought i was using it before in Win 7 along with TV tuner plugged into USB directly. EDIT: if i have used DVBViewer downloader and downloaded LAV splitter, audio and video codecs (that uses MPC HC, i have checked, same codecs), i also get no audio and video. On the list of the filters is only: EVR renderer empty and MPEG2-demuxer, if i click the second, no properities window appears or etc. Just nothing happens.
