niksu Posted January 19, 2006 Share Posted January 19, 2006 My FireDTV-S box will be arrive in few days. Recent days I'm searching for some good software to use with it and IMO the DVBViewer is the best one for me. BUT I have heard that the crypted channels like Canal+ doesnt work yet. Is that true? So the simple question is when I am able to watch Canal Digital channels crypted by Conax? I promise that you got the one new customer immediately after Conax works with FireDTV. -Niko Quote Link to comment
niksu Posted January 21, 2006 Author Share Posted January 21, 2006 What a nice and active support... Quote Link to comment
Griga Posted January 21, 2006 Share Posted January 21, 2006 Please consider that all supporters do it in their spare time. Nobody gets paid for it, so nobody has to. Most of them are users like you. Don't expect DVBViewer.com to be a big company with a support staff only waiting to serve you - rather an internet community with a lot of volunteers. We've got information about CI support from FireDTV, and it has been implemented in DVBViewer Pro, but not tested successfully yet. Maybe you will be asked to do it Quote Link to comment
-=[MiL]D.S.C.=- Posted January 22, 2006 Share Posted January 22, 2006 Hi guys, i´ve tested the newest DVBViewer Pro Beta (v3.2.7.2233) with FireDTV S/CI and my buddie´s DragonCam a few minutes ago. But without any success. The CI doesn´t work. I´ve also tried to use it with "FireDTV CI-Tool" running before starting DVBViewer, and without "FireDTV CI-Tool" running. But it doesn´t work. From now on, I can test everyday during the next 4 weeks, cause my buddie will be on vacation. Maybe it can be fixed soon. Quote Link to comment
niksu Posted January 22, 2006 Author Share Posted January 22, 2006 (edited) Sad to hear. I really hope that they can fix it. By the way does DVBV support 4:2:2 stuff? Edited January 22, 2006 by niksu Quote Link to comment
-=[MiL]D.S.C.=- Posted January 22, 2006 Share Posted January 22, 2006 Sad to hear. I really hope that they can fix it.<{POST_SNAPBACK}> They´re working on CI Support. I think they can fix it. They managed to fix bigger Problems than that. By the way does DVBV support 4:2:2 stuff?<{POST_SNAPBACK}> What do u mean with 4:2:2 Stuff? Quote Link to comment
Guest Lars_MQ Posted January 22, 2006 Share Posted January 22, 2006 4:2:2 depends completely on your video decoder, not the viewer, as far as I know Quote Link to comment
hackbart Posted January 22, 2006 Share Posted January 22, 2006 4.2.2 works since a loong time. Anyhow it is important that you use a decoder which handles 4.2.2 transmissions. Right now only the Elecard Decoder is capable of. Christian Quote Link to comment
niksu Posted January 22, 2006 Author Share Posted January 22, 2006 4.2.2 works since a loong time. Anyhow it is important that you use a decoder which handles 4.2.2 transmissions. Right now only the Elecard Decoder is capable of. Christian <{POST_SNAPBACK}> Okay. Do you mean that decoder setting which is under "DirectX" option in the settings? I have only NVIDIA Decoder in there. Quote Link to comment
hackbart Posted January 22, 2006 Share Posted January 22, 2006 in this case you need to install the elecard decoder too. There is a demo version of it available on their homepage (http://www.elecard.com/download/). Christian Quote Link to comment
emmel Posted January 22, 2006 Share Posted January 22, 2006 Try this: http://www.elecard.com/products/product.php?product_id=149 Once installed and registered, it will be available under the dx-settings. Quote Link to comment
niksu Posted January 22, 2006 Author Share Posted January 22, 2006 Thanks for your help! Now it is in my decoder list. I have to test those feeds(422) when I get my FireDTV tomorrow. Just make the Conax work and everything is perfect then! Quote Link to comment
