BelowSky Posted October 30, 2006 Share Posted October 30, 2006 I have seen EPG support through MediaHighWay & SiehFern in DVBViewer which (I think) do the same thing as OpenTV. So I'm wondering whether DVBViewer can support OpenTV too. Anyway, OpenTV is supported by several popular networks (click here to see them) and while googling for a solution, I found a very small source code distributed under the "GNU General Public License" that can receive that service. I don't know if its even allowed to ask that question, I really don't. But since that I don't know if its allowed, I will wait for your confirmation reply and I will be glad to point you the file. Quote Link to comment
MarkSS Posted November 2, 2006 Share Posted November 2, 2006 I have seen EPG support through MediaHighWay & SiehFern in DVBViewer which (I think) do the same thing as OpenTV. So I'm wondering whether DVBViewer can support OpenTV too. I've been looking for pointers on OpenTV to try and get access to the Sky UK EPG, perhaps initially creating an XMLTV file from it so standard plugins for a variety of applications could be used. Would be grateful for any pointers. Quote Link to comment
BelowSky Posted November 3, 2006 Author Share Posted November 3, 2006 (edited) I've been looking for pointers on OpenTV to try and get access to the Sky UK EPG, perhaps initially creating an XMLTV file from it so standard plugins for a variety of applications could be used. Would be grateful for any pointers. Are you a programmer? cause I am here talking about a code written in "C" programming language and involves some knowledge in Hexadecimal -> String conversion. No XML stuff. If you find out how to deal with it just let me know. Edited November 3, 2006 by BelowSky Quote Link to comment
MarkSS Posted November 3, 2006 Share Posted November 3, 2006 Are you a programmer? cause I am here talking about a code written in "C" programming language and involves some knowledge in Hexadecimal -> String conversion. No XML stuff. If you find out how to deal with it just let me know. By trade yes, not that I do much hands on coding these days The code and description makes sense, whether I can find the time to turn it into something useable is a different matter. Quote Link to comment
jf2020 Posted November 3, 2006 Share Posted November 3, 2006 Hi BelowSky, I'm supposed to be a programmer (at least that's what I'm getting paid for ) so I'd like to see if I could het this going. Can you please give me the pointer as well? Thanks! Quote Link to comment
BelowSky Posted January 3, 2007 Author Share Posted January 3, 2007 (edited) Sorry, wrong post deleted Edited January 3, 2007 by BelowSky Quote Link to comment
Whitey Posted January 10, 2007 Share Posted January 10, 2007 I too would like to see openTV EPG support in DVBViewer. XMLTV is ok but not every channel is supported Whitey Quote Link to comment
djdul Posted January 24, 2007 Share Posted January 24, 2007 I too would like to see openTV EPG support in DVBViewer. XMLTV is ok but not every channel is supported Whitey it will bet a great feature... dreambox already had it included in the vdr plugin (gpl). http://www.vdr-wiki.de/wiki/index.php/Otv4vdr-plugin hope it helps thanks for this great soft... Quote Link to comment
djdul Posted March 9, 2007 Share Posted March 9, 2007 Hi BelowSky, I'm supposed to be a programmer (at least that's what I'm getting paid for ) so I'd like to see if I could het this going. Can you please give me the pointer as well? Thanks! hello again; for a C, source pointer with complete opentv epg already made. follow http://vdr.bluox.org/download/?path=vdr-otv4vdr/ thanks in advance and hope it can help Happy coding PS: outof topic subject, is there any sample plugin in delphi with documentation (I start with the sdk but I don't found such a good plugin sample). Quote Link to comment
