supertack Posted November 15, 2006 Share Posted November 15, 2006 (edited) Hi...I've noticed recently a bug wich affects the scanning process, in both DVBViewer built-in scanner and the full version of transEdit MMC ! For example, when trying to scan some transponders on Nilesat (7°W), I got this picture : As you can see in red, channel names are reported as services followed by PID numbers. I tried other softwares and my home receiver in the same conditions (without moving miy dish, some LNB) , the names are shown correctly, so the bug comes from DVBViewer... But I noticed something else...when analysing the same transponder using TransEdit MMC, I see that names are reported correctly (unfortunatly only on analyse, not at scan) as you can see below : I noticed that during scanning, the SDT case take a long time to become green, so I tried also to add more time to scanner without success. I experimented also this bug on same transponders on Hotbird, Astra & Hispasat... My configuration : Hauppauge WinTV Nova-S-Plus with the latest driver DVBViewer Pro 3.5.0.100 (last version) TransEdit MMC full (last version) Pentium IV @ 2.4 GHz, 768 MB DD-RAM, GeForce FX 5200 (128 MB) Classic motorized dish, no DisecQ, 1 LNB (0.2 dB) Signal quality near to 95% on this transponder Thanks for help ! Edited November 15, 2006 by supertack 1 Quote Link to comment
Tjod Posted November 15, 2006 Share Posted November 15, 2006 Change the SDT Timeout in TransEdit Settings>Scanner2 SDT Timeout try a higher time. Quote Link to comment
Derrick Posted November 15, 2006 Share Posted November 15, 2006 ..fiddling with the time out won't help. It's a real bug that can be easily reproduced. The reason has to examined. The scanning engine doesn't read the SDT though there is a normal density of sections. The analyzer's parsing engine is working ok ps. @supertack, could you identify the other transponders that you've mentioned ? Quote Link to comment
supertack Posted November 15, 2006 Author Share Posted November 15, 2006 Thanks Derrick for your fast answer ! Well, I don't remember very well the exact transponders, but many ot them are actually on Nilesat... I downloaded an updated list from Joshy's fun and tried to scan Nilesat again, and after checking Lyngsat I saw that I missed my channel names on many transponders. That's all what I can tell you now. But I remember that I've got a correct channel list few weeks ago, using the same version of TransEdit MMC Other transponders with same problem on Nilesat : 12303 H 27500 3/4 12149 H 27500 3/4 (some channels) Maybe Nilesat is transmitting with new parameters ? But anyway, other softwares still giving the correct channel names... NB: when scanning Nilesat, just scan the transponders marked in lyngsat as "Egypt" beams. Others beams are for middle east only. I hope there is a fix for this bug ? Because it could affect so many interesting channels on other sats.... Quote Link to comment
Griga Posted November 15, 2006 Share Posted November 15, 2006 I hope there is a fix for this bug ? For tracking and fixing this issue I need a transponder that enables me to reproduce it. Astra 19/23/28° or Hotbird 13°, no SCPC / low symbolrate. Quote Link to comment
Derrick Posted November 15, 2006 Share Posted November 15, 2006 I could provide you with a recording of the SI tables. Quote Link to comment
Griga Posted November 15, 2006 Share Posted November 15, 2006 A pure SDT recording would be helpful (-> VRP). No other SI tables. Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 Ok, that revealed it - see attached image: - TS header, payload_unit_start_indicator set (4 bytes) - pointer field (= 0, 1 byte) - section with table_id 0x72 (ST, stuffing table, 8 bytes) !!! - section with table_id 0x42 (SDT actual) Same for all packets with payload_unit_start and a 0x42 table. The scanner's section parser expects 0x42 right after the pointer field. Dunno whether the NileSat method is ETSI compliant or not. There is no hint that something like this may happen. The specs say: 5.2.8 Stuffing Table (ST)The purpose of this clause (see table 11) is to invalidate existing sections at a delivery system boundary e.g. at a cable head-end. When one section of a sub_table is overwritten, then all the sections of that sub_table shall also be overwritten (stuffed) in order to retain the integrity of the section_number field. ...and about stuffing: Stuffing may be performed by filling each remaining byte of the TS packet with the value "0xFF". Consequently the value "0xFF" shall not be used for the table_id. If the byte immediately following the last byte of a section takes the value of "0xFF", then the rest of the TS packet shall be stuffed with "0xFF" bytes. These bytes may be discarded by a decoder. Stuffing may also be performed using the adaptation_field mechanism. ...and nothing more. The parser only handles these "recommended" kinds of stuffing. At least the NileSat method is quite unusual. Quote Link to comment
supertack Posted November 16, 2006 Author Share Posted November 16, 2006 Euh...may someone explain to me ??? It is a bug from DVBViewer ? Because, as I said, there is no problem with other softwares... I'll try to find some problematic transponders on the sats you requested : Hotbird and Astra Thanks, this forum is really fantastic ! Quote Link to comment
supertack Posted November 16, 2006 Author Share Posted November 16, 2006 Well, so maybe Nilesat is not using a non-standard method...but why other popular software works correctly ? That includes also my old Drake, a standard home demodulator built in 2001... Quote Link to comment
Derrick Posted November 16, 2006 Share Posted November 16, 2006 The parser only handles these "recommended" kinds of stuffing. At least the NileSat method is quite unusual. The stuffing table is an overwritten table that is invalidated and should be ignored. The FFs are part of this don't care table and should not be considered as stuffing in the sense of your 2nd cited passage. Whether this is unusual or not, it is imho allowed and no violation of the standard. That's why I (my personal opinion ) come to the conclusion that the parser should be fixed. Take the parser from the analyzer Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 It is a bug from DVBViewer ? This is not one of those movies for simple minded people that leave no doubt who is good and who is bad. The stuffing table is an overwritten table that is invalidated It doesn't look like it ever has been another table. I would expect a different length and some other content than 0xFF, because the purpose of the ST is to invalidate a sub_table (BAT or SDT in this case) by overwriting the table_id with 0x72, and nothing more. But all possible sub_tables are still present in this stream (SDT actual, SDT other, BAT). IMO they simply abuse the ST for ordinary stuffing. Nevertheless there are two basic questions arising from it: 1) May a single payload_unit contain different sub_tables (with different table_ids)? 2) How shall the parser handle unexpected table_ids (let's say, table_id 0x00 within a SDT stream)? Shall it try to read the length of this unknown section and skip it? That's what the analyzer does. Or regard it as corrupted data and discard the whole payload_unit? That's what the scanner does, thus being more crash-proof. Of course it is possible to add a simple "if 0x72 after pointer_field then skip stuffing_table" statement. But I prefer to solve issues like this more profoundly. Take the parser from the analyzer ...and kick all devices with hardware PID filter. Yes, why not? Quote Link to comment
Derrick Posted November 16, 2006 Share Posted November 16, 2006 It doesn't look like it ever has been another table. I would expect a different length and some other content than 0xFFwho cares? May a single payload_unit contain different sub_tables (with different table_ids)?why not? Within TS packets of any single PID value, one section is finished before the next one is allowed to be started Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 Have a look at Hotbird 12322 H. The scanner finds only some of the channel names, the analyzer at least more. So there is something to do... Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 Something to add, for better understanding: In many cases it's a question of balance, not of bug/fix. Software should reject as much as possible, and tolerate as much as necessary. Many crashes and all these buffer overflow exploits can only happen because software is too tolerant, processing data that is "out of bounds". Sometimes things don't work because software is too restrictive. Hard to understand for users... well, go to your kitchen and try to balance a wooden spoon on a knife edge. Then run with let's say 2.5 gsps (gigasteps per second), without losing the spoon. After that, you'll know what it's like to be a developer. Quote Link to comment
Derrick Posted November 16, 2006 Share Posted November 16, 2006 Have a look at Hotbird 12322 H. The scanner finds only some of the channel names, the analyzer at least more. So there is something to do... ..yes, indeed here's what tsreader finds (same as transedit's analyzer): hmm, I don't see the problem. There are 2 different sections with 0x42, a long one (length 0x3f3) and a short one (0x30). Both are alternating and start at the beginning of a ts_packet_payload with stuffing at the end. Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 Hotbird 12322 is a different issue. As you can see in the Analyzer, there are two descriptors in the SDT for the channels in question. A service_name_descriptor, containing the provider and service name, as it should be, and the scanner reads them. But it is followed immediately (in the same descriptor_loop) by a multilingual_service_name_descriptor, that specifies only two languages, but no names. The scanner reads this descriptor too, thus replacing the already retrieved names by empty strings. So I have to tell the scanner not to read a name if it has already got one for a channel. The Analyzer is not affected because it lists the content of the second descriptor separately. This is an example for being too tolerant, in contrast to the NileSat issue. Quote Link to comment
Griga Posted November 16, 2006 Share Posted November 16, 2006 Ok, as a first result, try TransEdit 3.0.1.2 -> members area, beta section. Hotbird 12322 H is ok now, NileSat don't know... don't expect too much, it's just a test version. I made the parser more tolerant, got a nice crash (endless loop) on a Hotbird transponder, made it a bit less tolerant again... as I said, balancing. Astra 19°/28° and Hotbird full scan without crash -> uploaded, though I'm not happy with certain aspects yet. @Derrick: This version is supposed to record *all* PIDs of a transponder, if you select the whole PID list in the Analyzer, even those that are not visible. With other words, selecting all disables filtering. Try... Quote Link to comment
Derrick Posted November 16, 2006 Share Posted November 16, 2006 The scan of the nilesat transponder shows all names ..but due to bad weather condition reception is poor Quote Link to comment
supertack Posted November 16, 2006 Author Share Posted November 16, 2006 (edited) The scan is perfect in both Hotbird & Nilesat using new version of TransEdit !!! Thanks Griga you're a genious ! And thanks for Derrick for your help too ! Now I think there is something to do with the DVBViewer built-in scanner, as no everybody is using TransEdit MMC (and they are wrong !) Thanks again...I'll tell you if I find similar problem on other satelites I'll scan today... I hope that there is no crash as you said ! Edited November 16, 2006 by supertack Quote Link to comment
Derrick Posted November 16, 2006 Share Posted November 16, 2006 I hope that there is no crash as you said ! ..he's hoping for a crash to support his theory of SI_tolerance Quote Link to comment
supertack Posted November 16, 2006 Author Share Posted November 16, 2006 (edited) :-D Edited November 16, 2006 by supertack Quote Link to comment
Griga Posted November 17, 2006 Share Posted November 17, 2006 Stop joking. It's a very serious matter I've digged a bit deeper in consideration of the relation between sections and payload units. The ISO specs say: When at least one section begins in a given Transport Stream packet, then the payload_unit_start_indicator shall be set to 1 and the first byte of the payload of that Transport Stream packet shall contain the pointer. When no section begins in a given Transport Stream packet, then the payload_unit_start_indicator shall be set to 0 and no pointer shall be sent in the payload of that packet. ...which means, a payload_unit may contain sections with different table_ids, if they all start in the same TS packet with payload_unit_start_indicator = 1. Even the Analyzer may fail to read a section, if *three* sections start within a packet, and the table_ids of the first two sections do not belong to evaluated tables (like 0x72, the NileSat stuffing table). In this case the Analyzer will skip the first section, and, after having encountered the second table_id, discard the rest, including subsequent packets with payload_unit_start_indicator = 0. I think I better change that too. Quote Link to comment
supertack Posted November 17, 2006 Author Share Posted November 17, 2006 (edited) Well, I tried to use the new version of TransEdit on few sat I can receive. Fortunatly, it was no crash during scan, but I noticed some "services" again... (probably because of bad reception conditions) .However, TransEdit is more sensitive than ever and I'm really satisfied ! If this may help you, you can find my scan result attached below in .ini format. Thanks again ! Scan_17_11_06.rar @ Griga : could you add a new option in TransEdit ? It would be helpful for us to choose our proper category during export (and not only Provider, Scan Date or Frequency). When I export, I always choose Scan Date, and after I modify the .ini file for converting the scan date to satellite name, as in root section. But this takes a lot of time, specially with big lists. And it's the only way if I want to obtain this result : Edited November 17, 2006 by supertack Quote Link to comment
Derrick Posted November 17, 2006 Share Posted November 17, 2006 Even the Analyzer may fail to read a section, if *three* sections start within a packet, and the table_ids of the first two sections do not belong to evaluated tables (like 0x72, the NileSat stuffing table). In this case the Analyzer will skip the first section, and, after having encountered the second table_id, discard the rest, including subsequent packets with payload_unit_start_indicator = 0. I think I better change that too. Maybe you have to repeat this. I don't quite understand.. ..of course there could be more than 2 sections starting in one and the same ts_packet. Theoretically speaking at least. What could be the use of this other than bothering stressed developers, I don't know You have to think of sections that can be short by default, e.g. like some ecms. Further the section rate has to be quite high which means a single section in a ts_packet is a real waste of bandwidth. There might be other reasons.. Quote Link to comment
Griga Posted November 17, 2006 Share Posted November 17, 2006 but I noticed some "services" again... There are always "service xxxx" entries, because the SDT contains no service_name_descriptor for some channels. Always compare it with other sources (DVB, not LyngSat) before posting it as a bug. could you add a new option in TransEdit ? I don't understand what you want. Please try again in the Plugins or Feature Requests Section of this forum, since it is not bug-related. I don't quite understand.. .. Examining the code revealed that the Analyzer's section parser is restricted in the same way as previously the one of the scanner, affecting the third (scanner: second) and following sections. I've changed it, though I don't expect much practical relevance. Quote Link to comment
Derrick Posted November 20, 2006 Share Posted November 20, 2006 ..something else. Dunno whether it fits here Apparently there are streams that don't contain a SDT but a service descriptor 0x48 is used in the PMT. No action needed, just for information. It's only a data stream anyway.. Quote Link to comment
