funny TOT
Derrick
In DVB there are tables defined that give an indication for the time (TDT) as UTC and an offset (TOT) for the local time.
Here's an example of a TOT that I haven't seen so far :)
<?xml version="1.0" encoding="iso-8859-1" ?>
- <Astra_1D_3A_at_23.5_E_11953_H>
- <TOT PID="0x0014">
 <DateTime String="23.11.2006 23:15:41" />
- <Descriptor HValue="0x58" Name="Local Time Offset">
- <Country String="DEU">
 <CountryRegionID Value="0" />
 <LocalTimeOffsetPolarity Value="0" />
 <LocalTimeOffset String="01:00:00" />
 <TimeOfChange String="25.03.2007 02:00:00" />
 <NextTimeOffset String="02:00:00" />
 </Country>
- <Country String="AUT">
 </Country>
- <Country String="CHE">
 </Country>
- <Country String="LUX">
 </Country>
 </Descriptor>
 </TOT>
 </Astra_1D_3A_at_23.5_E_11953_H>
Here is an example of a channel that claims to broadcast MPEG1 Video:
<?xml version="1.0" encoding="iso-8859-1"?>
 <Astra_19.0_E_11538_V>
<ServiceID Value="6905" Name="France 24 (en Francais)">
  <PMT PID="655">
	<PCR PID="605"/>
	<ES PID="605" Name="MPEG1 Video">
	  <StreamType HValue="0x01" Name="MPEG1 Video (ISO/IEC 11172-2)"/>
	</ES>
	<ES PID="625" Name="MPEG Audio">
	  <StreamType HValue="0x03" Name="MPEG Audio (ISO/IEC 11172)"/>
	</ES>
  </PMT>
</ServiceID>
 </Astra_19.0_E_11538_V>
Consequently the TransEdit Preview, when started from the analyzer window, does not play the video stream, because the Analyzer wants to see MPEG2 or H.264. However, when started from the scanner window, the Preview plays it, because the scanner doesn't care... :)
P.S. Obviously it isn't MPEG1 video, because it's interlaced, and the sequence header is followed by the extension_start_code 00 00 01 B5. Stream type 0x01 is simply wrong.
Edited by Griga
..at least the service can be watched with all applications that I have checked. TSReader says it's mpeg1 but at the same time parses the stream and gets the correct parameters.
Elementary Stream PID 606 (0x025e) MPEG-1 Video
MPEG Video: Bitrate 15.000 Mbps Resolution 720 x 576i
MPEG Video: Framerate 25 fps Aspect Ratio 4:3 Chroma Format 4:2:0
btw. stream type 1 is inserted by the old dvb2000 in the CA_PMT for video as a fixed value :)
Sure. It's plain MPEG2.
Fooled by the wrong stream ID, like the analyzer. Retrieving the correct type requires parsing the ES (me -> hex viewer).
Information: 1005  TPT->PES(PID=606), MPEG 1 Video->VES(224)->This is an MPEG-2 Video Elementary Stream
Semantic Error: 1014  TPT->PES(PID=606), MPEG 1 Video->VES(224)->PSI in Transport Stream specifies MPEG 1 Video
..they won't get away with this crap ! :)
A wrong TOT (not updated to local_time_offset = 01:00:00 and next time of change):
 <Astra_19.0_E_10920_H>
<TOT PID="20">
  <DateTime String="24.11.2006 11:50:20"/>
	<Country String="CZE">
	  <CountryRegionID Value="0"/>
	  <LocalTimeOffsetPolarity Value="0"/>
	  <LocalTimeOffset String="02:00:00"/>
	  <TimeOfChange String="29.10.2006 01:00:00"/>
	  <NextTimeOffset String="01:00:00"/>
	</Country>
	<Country String="HUN">
	</Country>
	<Country String="SVK">
	</Country>
  </Descriptor>
</TOT>
 </Astra_19.0_E_10920_H>
  • 8 years later...
A wrong TOT (not updated to local_time_offset = 01:00:00 and next time of change):[/code]
Don't think that's a thing of the past:
<?xml version="1.0" encoding="utf-8"?>
<Cabel__QAM_256__314>
<TOT PID="20">
<DateTime String="10.04.2015 17:41:33"/>
<DescriptorLength Value="13"/>
<LocalTimeOffset String="01:00:00"/>
<TimeOfChange String="29.03.2015 01:00:00"/>
<NextTimeOffset String="02:00:00"/>
</Country>
</Descriptor>
</TOT>
</Cable__QAM_256__314>
