dsundelin 0 Posted December 8, 2007 Share Posted December 8, 2007 Bought DVBViewer yesterday and tried to install it but its impossible. After installtion and channel scan I found about 150 programs and the channellist is ok. The problem comes when i try to watch a channel, the screen goes black and says no signal (screen msg) and i have to restart the computer. I have tried to reinstall windows xp but still have the same problem. Change screen but same. I used Mediaportal before and that worked fine accept some bugs thats why i choosed to pay for some proper software but now i i cant even see the channels. Hope someone can help me with this problem. Hardware AMD X2 4600+ 2gb Ram Floppydtv ATI 9800XT Software Win XP pro FFDShow and I have also tried cyberlink Floopdtv drivers Omega ati drivers Quote Link to post
Lars_MQ 82 Posted December 8, 2007 Share Posted December 8, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote Link to post
dsundelin 0 Posted December 8, 2007 Author Share Posted December 8, 2007 Sry for that. Here´s the support file. I have tried some more and notice when the channel has no picture (no signal) it works, its when the picture comes it chrashes. So it has to be something with video output? support.zip Quote Link to post
Lars_MQ 82 Posted December 8, 2007 Share Posted December 8, 2007 options -> directx -> select: video renderer: overlay audio decoder: cyberlink Quote Link to post
dsundelin 0 Posted December 8, 2007 Author Share Posted December 8, 2007 (edited) Tried that before and did it again but still the same problem. Computer freeze and then black screen and I have to reboot. Theres no archive with older versions that i can try? Edited December 10, 2007 by dsundelin Quote Link to post
dsundelin 0 Posted December 12, 2007 Author Share Posted December 12, 2007 I would appreciate some more tip around this problem. I have spent to much hours trying to solve the problem so plz some more support would be nice. Quote Link to post
dezzy 0 Posted December 13, 2007 Share Posted December 13, 2007 You are not alone. Up until today my 3.9.1 update was working fine. However, since the Windows automatic update last night it behaves as you describe. A black screen when selecting a channel and the computer shuts down and reboots after closing DVBV. All my DirectX settings remain as before, when it was working properly. Luckily I still have the 3.8.0 installer and this version works fine for the time being. When I have time I will try to reinstall 3.9.1 again. Quote Link to post
dsundelin 0 Posted December 13, 2007 Author Share Posted December 13, 2007 You are not alone. Up until today my 3.9.1 update was working fine. However, since the Windows automatic update last night it behaves as you describe. A black screen when selecting a channel and the computer shuts down and reboots after closing DVBV. All my DirectX settings remain as before, when it was working properly. Luckily I still have the 3.8.0 installer and this version works fine for the time being. When I have time I will try to reinstall 3.9.1 again. Hmm I see! That was not good. You dont know if its possible to download 3.8.0? is there any archive here? Quote Link to post
dezzy 0 Posted December 14, 2007 Share Posted December 14, 2007 When I have time I will try to reinstall 3.9.1 again. I tried 3.9.1 again but it still does not work. What is causing this? It worked perfectly until a few days ago. The older version also works perfectly currently. Are we the only two people on Earth who are having this problem? Am I missing something simple? Quote Link to post
ricabullah 0 Posted December 14, 2007 Share Posted December 14, 2007 dezzy, are you using XP as well? Quote Link to post
Tjod 298 Posted December 14, 2007 Share Posted December 14, 2007 Pleas post a support.zip including a debug.log from the crash. To generate a debug.log you have to start the DVBViewer with DVBViewer.exe -debug. May be it shows the reason for he crash. Quote Link to post
dezzy 0 Posted December 14, 2007 Share Posted December 14, 2007 Ok, I am back in business with 3.9.1. It works normally again. I downloaded a new copy of the installer file and no further problems. It seems that the original installer may have been corrupted in some way. Thanks for your interest and responses. Yes, I am using XP SP2, updated to the latest patches. Perhaps the OP should also try a new download. Quote Link to post
dezzy 0 Posted December 15, 2007 Share Posted December 15, 2007 I should add that I just noticed that the new version that works perfectly is 3.9.1.1 It probably makes all the difference. Quote Link to post
dsundelin 0 Posted December 19, 2007 Author Share Posted December 19, 2007 I should add that I just noticed that the new version that works perfectly is 3.9.1.1 It probably makes all the difference. I still have the problem. Where did you find the update 3.9.1.1? I can only find 3.9.1.0. Quote Link to post
dezzy 0 Posted December 19, 2007 Share Posted December 19, 2007 I still have the problem. Where did you find the update 3.9.1.1? I can only find 3.9.1.0. Nothing special, just the latest download version from the Members Area. I was not aware that it had changed until I checked the About > Info menu. If you are still having problems, I suggest that you e-mail for support. Quote Link to post
