DVBViewer TE Cannont Tune in this Channel
SatViewer
Hello!
I'm trying to tune in the following channel
Adjaratv
Hot Bird 13 E
Fr. 11,411 GH z
Pol. H
S/R 27 500
Fec. 5/6
Other programs find this channel by scanning, DVBViewer techinisat edition cannot. The problem appeared after the channel changed its frequencies. I cannot make the channel work either by entering frequencies and pol., s/r etc or by auto scan. It's a free-to-air channel. I have all needed codecs: NVidia, Intervideo, Sonic, AC3 etc. Please write your settings if you can tune in. Thank you.
Thank you so much!
No idea why I can't scan the channel myself. Maybe too weak signal?
Thanks again ;)
  • 3 years later...
I don't want to make a new topic. This is similar so I will write the problem here.
Since this topic was create there were changes on this Tp. Now it's contain DVB-S2 data:
DVB-S2
8PSK
SR 27500
FEC 5/6
The problem is that the DVBViewer can't scan it. While scanning, the PAT becomes red. I've checked signal from this TP on other software, and it's quite good ( better than on other tp ). I've make a test and added one of the channel manualy. It's works for few hours without problem. ( no freezeing or pixelization ).
Is there any Way to make DVBViewer to scan this Tp property for future use ?
Thanks.
BR, Mariusz
DVBViewer: 4.9.0
Hardware: SkyStar HD2
OS: Win7x64
Scans OK here, not using Skystar HD2
using Skystar HD2, everything works fine, scan works perfect too
