Lars_MQ Posted September 15, 2008 Posted September 15, 2008 Meine Empfehlung: Bloss Finger weg davon. Scheint noch sehr buggy zu sein: hat probleme TS dateien wiederzugeben, crasht öfters (was die alte version nie machte) und streaming funktoniert mit der version nicht mehr. Quote
IRa Posted September 15, 2008 Posted September 15, 2008 ..plays H.264 ok I am very disapointed, it seems to very random if VLC plays any TS files (Did you try to say the same Lars ?)This is with normal DVB-T TS recordings, I have some HD recordings from Peging olympics (also DVB-T) and no change to look them with this VLC version. Quote
Lars_MQ Posted September 15, 2008 Posted September 15, 2008 I'm sorry, didn't realize I'm in the english part. I'll try again: I tested it and my suggestion: Don't use it, stay with the old one for now. It seems quite buggy to me, has problems playing TS files and crashes a lot. And streaming with recording service or web interface does NOT work with this version... Quote
Derrick Posted September 15, 2008 Author Posted September 15, 2008 (edited) ..all H264.ts files are played well. That's what I'd tried in the 1st place. Other files can be a problem. Sometimes it works btw. streaming from the DVBViewer (plugin) and from tsreader works well.. Edited September 15, 2008 by Derrick Quote
Kuni Posted September 15, 2008 Posted September 15, 2008 I'm sorry, didn't realize I'm in the english part. I'll try again: I tested it and my suggestion: Don't use it, stay with the old one for now. It seems quite buggy to me, has problems playing TS files and crashes a lot. And streaming with recording service or web interface does NOT work with this version... And yet it's the ONLY piece of software that will play my 10gig Spiderman3.mkv HD rip. Quote
IRa Posted October 21, 2008 Posted October 21, 2008 It seems to very random if VLC plays any TS filesNew VLC 0.9.4 seems to work much better with normal TS files but not with DVB-T HD recordings. Quote
