finner 0 Posted November 22, 2008 Share Posted November 22, 2008 (edited) I face this problem with my recently purchased skystar hd-2 and DVBViewer pro. When i search for channels the dvb-s2 channels arent always visible.I mean i have 98% quality/level and after a few zaps to other channels i cant get any signal.I have to close the application and start it again.This happens only with dvb-s2 channels. I m using coreavc 1.8 and latest dirvers from technisat website. Could it be a drivers problem? Edited November 22, 2008 by finner Quote Link to post
finner 0 Posted December 2, 2008 Author Share Posted December 2, 2008 I face this problem with my recently purchased skystar hd-2 and DVBViewer pro.When i search for channels the dvb-s2 channels arent always visible.I mean i have 98% quality/level and after a few zaps to other channels i cant get any signal.I have to close the application and start it again.This happens only with dvb-s2 channels. I m using coreavc 1.8 and latest dirvers from technisat website. Could it be a drivers problem? Anyone can confirm that the card works fine with both dvb-s and dvb-s2? Quote Link to post
newlynx 0 Posted December 4, 2008 Share Posted December 4, 2008 I have the twinhan card (identical to skystar 2 hd) and face no problem with dvb-s2 channels. Try the powerdvd 8 h.264 drivers and tell us if that helps. Quote Link to post
finner 0 Posted December 4, 2008 Author Share Posted December 4, 2008 I tried both coreavc and pdvd8 codecs.The problem is that i cant any signal at all.After a few chanel zaps i lose everythin.I have turn off my computer,start it again and MAYBE i ll have signal. Quote Link to post
pilleje 0 Posted December 6, 2008 Share Posted December 6, 2008 I have skystar hd-2 (driver 1.1.0.402) + DVBViewer 3.9.4.0 + pdvd8 codecs and I 'm experiencing the exact same problem that you have described... after few channel zaps I have to restart. Quote Link to post
finner 0 Posted December 6, 2008 Author Share Posted December 6, 2008 I tried the card in another PC with different and maybe better satellite installation and the problem remained.At first the card worked with DVB-S chanells but after a few zaps the signal was gone. I tried with 1.1.300, 1.1.302, 1.1.400 and 1.1.402 mantis drivers.All the same :/ Quote Link to post
hercum 0 Posted December 7, 2008 Share Posted December 7, 2008 (edited) Hi, I have a skystar hd and I know the problem I only have it with encrypted channels. You only have it when changing from dvb-s to dvb-s2 right? There isn't really a solution just restart DVBViewer or in the menu->view->rebuild graph. Edited December 7, 2008 by hercum Quote Link to post
finner 0 Posted December 8, 2008 Author Share Posted December 8, 2008 No it happens with all channels both dvb-s and s2, Using progdvb,dvbdream etc i have the same problem too so it must be the card or the drivers Quote Link to post
varesino 0 Posted December 8, 2008 Share Posted December 8, 2008 No it happens with all channels both dvb-s and s2,Using progdvb,dvbdream etc i have the same problem too so it must be the card or the drivers I have the same board from MSI with driver 1.1.0.400 and it works without problem. For your info the same board is on market also with this name: Terratec Cinergy S2 PCI HD CI On Terratec web site you can find a Mantis driver ver. 1.1.0.601 that seems newer. Unfortunately there isn't any history log. Regards Quote Link to post
finner 0 Posted December 8, 2008 Author Share Posted December 8, 2008 Thanks for the reply! I ll try those drivers! Could you tell me which lnb are you ising and how big your dish is? Quote Link to post
finner 0 Posted December 8, 2008 Author Share Posted December 8, 2008 Well it seems that these drivers cannot be installed for Skystar HD2. I tried on XP and Vista SP1 Quote Link to post
hercum 0 Posted December 8, 2008 Share Posted December 8, 2008 I'm starting to think it's more hardware related, probably manufacturing error. It happens more then you think, I had to swap my skystar 2 a few years ago because of similar problems actually. Assuming that you still got warranty on it, you might want to consider trading it for a new one. However, I suggest you try some more things like checking your cables and lnb's etc. first. Because you have to send your card back to the store and they have to send it to the factory and they have to check if there really is a problem with it,... It takes quite some time (guessing a week or 2 maybe 3 before you have a new/repaired card) Quote Link to post
finner 0 Posted December 8, 2008 Author Share Posted December 8, 2008 Hercum i already checked my card in another computer with better satellite setup and i had the same problem so i pressume is not my dish nor my lnb :/ Technisat replied by saying that i may be a faulty tuner or the motherboard can give enough current. Quote Link to post
hercum 0 Posted December 9, 2008 Share Posted December 9, 2008 Well then it most probably is the card, so you are running out of options. I suggest you return it, putting it in an other computer and still having the same problem makes that pretty clear. As I said before it will take a while but since more people are having that problem they will send you a new card right away. Probably production error on a whole pack of cards (like it was in my case back then ) They actually give you a little hint in there reply about that, they just don't like admitting it (again same as with me ) Quote Link to post
finner 0 Posted December 9, 2008 Author Share Posted December 9, 2008 Heheh i guess thats the way thing work in corporations.It just happened before xmas season and i think i might have to wait till 2009 to get the new one :/ Quote Link to post
hercum 0 Posted December 9, 2008 Share Posted December 9, 2008 Didn't look at the calender before, it's very likely that you're right about that, or you might just get a nice x-mas present Quote Link to post
