finner Posted January 12, 2009 Share Posted January 12, 2009 Technisat released a new version for the Skystar HD2 product. 1.1.1.302 12-10-2008 People using vista x64 please inform us if the "over 3gigs of ram" issue is solved! Quote Link to comment
newen Posted January 17, 2009 Share Posted January 17, 2009 (edited) Technisat released a new version for the Skystar HD2 product. 1.1.1.302 12-10-2008People using vista x64 please inform us if the "over 3gigs of ram" issue is solved! I guess there is no easy answer on that I've made clean Vista x64 install and gave new drivers a go. I didn't use supplied setup but manually picked drivers from device manager. Installed fine with no problems. I've updated transponders (Astra 19,2 and HB in my case) and went to channel scan. I've used Scan range option and 3 green lights appered! 5 channels found! Woooooohooooo! But....but....wait! What is this? DVBV managed to successfully scan only first frequency. Rest is red PMT. Then I tried moving starting freq to chan 2. Scan range. Few more channels on frequency 2 found. Next channel Red = PMT. I guess i can scan them all like that And they work (picture and sound). Now, I've tried different option combos in card setup (direct tunning on/off, open whole transponder, stop stream...) but i was unable to make channel scanner to work as intended. But this is defenetly a step forward. Edited January 17, 2009 by newen Quote Link to comment
newen Posted January 17, 2009 Share Posted January 17, 2009 Update 1: Transedit 3.2.7-beta scans all channels with no problem but when i try to export channels it gives me "No DVBV GE/Pro installed. Quote Link to comment
Griga Posted January 17, 2009 Share Posted January 17, 2009 1) TransEdit.exe must be stored in the DVBViewer installation directory (where DVBViewer.exe is). 2) TransEdit expects the file channels.dat in the DVBViewer configuration folder (see About Menu in DVBViewer Pro). Quote Link to comment
finner Posted January 17, 2009 Author Share Posted January 17, 2009 Newen thanks for the feedback! I cant wait to get back my new ss2 HD after replacing the broken one i first bought and try myself. Quote Link to comment
newen Posted January 18, 2009 Share Posted January 18, 2009 1) TransEdit.exe must be stored in the DVBViewer installation directory (where DVBViewer.exe is). 2) TransEdit expects the file channels.dat in the DVBViewer configuration folder (see About Menu in DVBViewer Pro). You are too polite for a moderator Griga RTFM would have been a good enough answer for me Quote Link to comment
newen Posted January 18, 2009 Share Posted January 18, 2009 Update 2: After a push in right direction (thanks Griga) I managed to scan both Astra and HB channels in Transedit. I exported the channels and then imported them in DVBV. There was a problem switching channels but I've solved it by unchecking the "Stop stream while tuning" option in Hardware setup for SSHD2. So far so good. My next step will be buying a CI interface and trying to use a TotalTV card in it. Anyone with expirience with that combination? Quote Link to comment
finner Posted January 22, 2009 Author Share Posted January 22, 2009 I got my new card today and i d like to confirm that the new drivers work like charm in Vista x64! Quote Link to comment
newen Posted January 24, 2009 Share Posted January 24, 2009 I got my new card today and i d like to confirm that the new drivers work like charm in Vista x64! did you expirience tunning problems within DVBViewer like I did? Quote Link to comment
finner Posted January 25, 2009 Author Share Posted January 25, 2009 Not at all.On the contrary DVBViewer Pro 4 found all the available channels in hotbird while in Transedit i could get signal! Quote Link to comment
jim carey Posted February 6, 2009 Share Posted February 6, 2009 Not at all.On the contrary DVBViewer Pro 4 found all the available channels in hotbird while in Transedit i could get signal! tank you Quote Link to comment
