ml 05019 Posted November 17, 2009 Share Posted November 17, 2009 I have DVBViewer latest beta (.30) and am having the following problem: if DVBViewer crashes (usually it's ffdshow fault), the error report window is done collecting information etc., DVBViewer window is closed but the process remains in task manager. It then cannot be suspended or killed, and prevents the new instance of DVBViewer to be run (the loading stops on "Evaluate commandline parameter"). To get rid of this process, I can restart computer (logging out doesn't help - the process is still there) or wait for process to close itself - it takes about 5 minutes. This problem first appeared on version 4.2.1, but then I wasn't sure if configuration folder left from previous versions wasn't the problem. Now, I recently cleaned it out and ran configuration wizard again - and now, I get this problem again. Data: Windows 7 CPU Celeron 1.6 GHz, RAM 1 GB, GPU Intel 945GM K-Lite codec pack 5.20 DVBViewer 4.3.0.30 AverMedia E568 Quote Link to comment
