Gioxy Posted March 15, 2010 Posted March 15, 2010 I'm wondering from where really belong this series of language items I found at the end of english.lng [OSD] section... Scantxt=Channelscan: %d%s done (%d new channel(s) found) Scan=Start Scan Satellite=Satellite Terrestrial=Terrestrial Cable=Cable ATSC=ATSC csReceptiontype=Please choose the receiption type you want to use for the channel scan. Do you receive TV from more than one satellite?=Do you receive TV from more than one satellite? If you choose "No" DiSEqC will be disabled.=If you choose "No" DiSEqC will be disabled. csLNB=You can connect up to 4 satellite positions on a DiSEqC able DVB-S device. Which Positions do you use? csTransponderlist1=Choose the satellite you can receive on Position 1. csTransponderlist=Choose the satellite you can receive. csTransponderlist2=Choose the satellite you can receive on Position 2. csTransponderlist3=Choose the satellite you can receive on Position 3. csTransponderlist4=Choose the satellite you can receive on Position 4. csScan=The system is ready to start the channel scan. csScanning=The system scans for channels now. This will take several minutes. csScandone=The channel scan is finished. %d Channels updated=%d Channels updated. %d new Channels found=%d new Channels found. Scan Channels=Scan Channels This will stop (TV) playback=This will stop (TV) playback and will stop any ongoing timeshift=and will stop any ongoing timeshift Continue?=Continue? Quote
Lars_MQ Posted March 15, 2010 Posted March 15, 2010 Well that's something for later, you don't need to translate it for now. Quote
Gioxy Posted March 15, 2010 Author Posted March 15, 2010 Ah, that's why I don't found them in the OSD... ok, no problem to translate them now, just a few minute... Quote
