Fulco Posted April 2, 2010 Share Posted April 2, 2010 Running Register_DVBSource.exe (Windows 7, 64bit), with Administrator rights, fails with message: “Registering/unregistering filters requires administrator rights!”. I copied Register_DVBSource.exe and Pushsource.ax (DVBViewer_Filter_3_5_2) to the filters directory. Please help. Quote Link to comment
Tjod Posted April 2, 2010 Share Posted April 2, 2010 You need full Administrator rights. Right click on the Register_DVBSource.exe an select run as Administrator. Quote Link to comment
ak2010 Posted April 7, 2010 Share Posted April 7, 2010 I did. You have to enable the administrator account as follows. C:\Windows\System32\gpedit,(Double click gpedit)Then under Computer configuration Double click Windows Settings,double click Security options,double click Local policies,double click Security options. Then in the right pane Top line Accounts: Administrator Account Status...( Double click and enable). Then Log off and Log in to Administrator account. You might have to restart Computer i can't remember. You can leave the Adminstrator account enabled but still use your account and when you need to register .ax files Log off and Log in to Admin account. (Using the Computer in Administrator Account isn't recommended.Less secure). Quote Link to comment
Fulco Posted April 8, 2010 Author Share Posted April 8, 2010 Thanks! Login as Administrator did the job. Quote Link to comment
