Girder
admi-ral
i use girder but experienced a curious problem. My Remote (via Igor) sends different evenstrings whether DVBViewer is open or not. That means one key on the remote sends two different types of commands.
I know that a remote can send many different commands with one key but thats something else. There are usually between 4-7 different eventstring of one key. If DVBViewer is started they are now totally different:
DVBViewer open: commands like c03fec03d
DVBViewer closed: 380, e03, 70, 700
has anyone an idea?
Link to comment
Which kind of Receiver du you use?? Is the input Signal over DCD, DSR or CTS??
Maybe your Remote don't work together with your receiver. Whcih speed is selected for the com port??
Link to comment
try another remote-control. Just to sort out some possibilities.
Read again the guides on the internet on how to setup girder and also igor-plugin correctly.
Aslo try here:
Igor Site
Edited by Technofriend
Link to comment
