Lars_MQ Posted September 15, 2011 Posted September 15, 2011 We have released the new DVBViewer Pro 4.9 today. ATTENTION: You can download the DVBViewer Pro 4.9 only from https://www.DVBViewer.tv/members/ We introduced a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: http://www.DVBViewer.tv/forum/topic/42222-how-to-get-new-credentials/ Mit der Version 4.5 wurde ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: http://www.DVBViewer.tv/forum/topic/42223-neue-benutzerdaten/ The changelog: MHEG-5 Add: TOT data generated by the system time Add: Audio play states are now handled by the MHEG engine Add: Video play states are now handled by the MHEG engine Add: partially support for online content like BBC iPlayer Fix: Volume control of the MHEG engine should work correctly Fix: Interactive language is now send to the MHEG application correctly Add: PVR Bookings are send/read to/from the VCR Video On Demand Filter Add: Youtube support (youtube://[youtubeid]) Add: Vimeo support (vimeo://[vimeoid]) Fix: Improved Playback and buffering of all kind of audio and video streams Add: Better Icecast/Shoutcast detection Removed: LastFM support General Add: Playback Presets by Griga. Presets are used to offer a more flexible way to select codecs and splitters for specific file formats. Note: selecting a Videorenderer inside these preset files is NOT supported.Some example presets are in the [app-folder]\GraphPresets_Samples. You need to copy them into the [configuration folder]\GraphPresets\ folder and adjust the filter IDs and/or make sure you have the fitting filters/splitters installed. Add: Playback: Added CD and WAV playback via the DVBSource Filter. Change: Program: Saving of the windows positions is now handled a little better. Fix: Program: The position of dialog windows was sometimes incorrect. Add: Playback: Playback of ts/mp3/wav streams from a http source (Recording Service) via the DVBSource filter added. Use the "Open URL" dialog. Needs the current version of the Recording Service. Fix: Installation: A clean installation with no channel list as a Recording Service client could deactivate all timers in the Recording Service. Fix: Program Start: under certain circumstances a renderer error message could delay the program start up to 20 seconds. Fix: Recordings: If adjust PAT/PMT was activated and the SID of a channel was wrong, no Audio/Videodata was written. Now adjust PAT/PMT is deactivated if the SID doesn't match. careful this might cause problems with other hard/Software. Make sure the SID of a channel is always correct. Change: Rewritten and optimized the code for (debug)Logfile writing. Fix: Settings: Changes to Auto detect Audio/Video weren't saved anymore. Updated to current sqlite3 version. Updated the DVBViewer Filter. Several corrections and optimizations. Language files updated. Hardware Add: Skystar USB HD with WDM driver: Enabled Diseqc 1.2 for this device. Add: BDA: DiSEqC support for DVBSky devices added. Add: BDA: Detection of Digital Devices Cine CT V6 devices added. Add: BDA: Reworked the detection of Turbosight devices. You might have to do a manual hardware search in the options. Add: BDA: Cinergy HTC Stick detection added. Change: BDA: New option for EMPIA compatible devices in DVB-C mode in the hardware Options: "Force Auto Modulation". Changing this value might help if channel changes are very slow. Add: Support for Hauppauge PVR devices
