ASAKURA Posted November 12, 2011 Share Posted November 12, 2011 (edited) Plugins - X.dll, MyScrobbler.dll, concinnity.dll, miniepgvars.dll - Plugins_xp.zip28.02.2012 - online video plugin and images -Online Video28.01.2012 - ADD page - MySeries is a plugin for DVBViewer Pro.Fonts : in folder of skin (font)Folder images u must downloadDownload - http://htpc.is-great...pic.php?f=5&t=4Please write about mistakes!!!__________________________________________________________________________________________________________________Update 28.02.2012ADD : Online VideoADD : MySeriesFIX : myTimer and DialogDateandtimeДля русскоязычного населения Форума - http://htpc.is-great...pic.php?f=5&t=4Please see also oure other skins for installation:X-perienceReflexBlack and White + AeonMediaportalTitanColorizzz (new!!! still in work)Enjoy it. Edited September 8, 2013 by ASAKURA 1 Quote Link to comment
moremax Posted November 12, 2011 Share Posted November 12, 2011 Hi, i´m sorry to say, that you´ve made an doupplepost for your interesting Skin, but hardest, you forgott the File for Download?! Regard Oliver Quote Link to comment
moremax Posted November 13, 2011 Share Posted November 13, 2011 Hi, me again. I want to say thank you, for this nice Skin. I customized some (Time in EPG etc) Scrobbler is known, but i´m not sure what X.dll is?! There are a lot of Information when i Google it... can you write a Link or what this dll will be do, please? Regard Oliver Quote Link to comment
ASAKURA Posted November 13, 2011 Author Share Posted November 13, 2011 Here it is, please Plugins.zip Quote Link to comment
hackbart Posted November 13, 2011 Share Posted November 13, 2011 The x.dll is part of the x-skin. You can find the skin in the forum too Quote Link to comment
hackbart Posted November 13, 2011 Share Posted November 13, 2011 привет товарищу, the skin is really nice, but several pages need a bit polish. For instance mymusicfiles, especially the thumbnailpanel and the info size on the right. The Fontsize is much too small to read it on a tv - better use font 18 for each info text. Then i miss the up/down buttons on the info listbox. I suppose you have hidden this by design, but after increasing the font size it might be handy to have it. The thumbnailpanel is completely incomplete, since the spaces do not fit which, means you get either 2 rows with 3 icons or one row with 3 big thumbicons. I will probably fix this later today... I also miss the images for the timeline Also some colors mismatch, dark grey on dark blue is extremely heavy to read. держать на хорошую работу Quote Link to comment
nemosja Posted November 13, 2011 Share Posted November 13, 2011 I have it looks like this Quote Link to comment
ASAKURA Posted November 13, 2011 Author Share Posted November 13, 2011 (edited) I also miss the images for the timeline sorry, i can't find the type of OSD menu. Also some colors mismatch, dark grey on dark blue is extremely heavy to read. a little more precisely if you can, not understend to nemosja Если русский пиши по русски=) I fix. one moment and i attach mychannels.xml dialogInfo.xml (fix) Edited November 13, 2011 by Starkun Quote Link to comment
nemosja Posted November 13, 2011 Share Posted November 13, 2011 Классный скин сейчас всё показывает правильно, спасибо. Quote Link to comment
ASAKURA Posted November 13, 2011 Author Share Posted November 13, 2011 И тебе за выбор этого скина fix timeline! download new file in first post Quote Link to comment
nemosja Posted November 13, 2011 Share Posted November 13, 2011 Эти меню тоже может быть нужно исправить. Quote Link to comment
ASAKURA Posted November 13, 2011 Author Share Posted November 13, 2011 Принимай! Fixid! DialogPopUpMenu.xml Quote Link to comment
nemosja Posted November 14, 2011 Share Posted November 14, 2011 Ещё одно меню неправильно отображается. Хотелось бы иметь подсказки в основных меню, примерно такие. Основное меню у Вас на скриншоте выглядит супер, у меня по-другому. Как сделать как у Вас? Скриншоты прилагаю. С уважением. Quote Link to comment
hackbart Posted November 14, 2011 Share Posted November 14, 2011 Hi, i fixed a problem inside mycam and i also changed the Thumbnail panel in the Mymusicfiles. The Icons now fit better in the region, which means you have 3x4 Small Icons and 3x3 Big Icons instead. I also played with hiding the caption of each thumbnail in order to do some image wall and this one looks quite nice. I've uploaded a second sample (mymusicfiles.zip).. Christian mycam_and_mymusicfiles.zip mymusicfiles.zip Quote Link to comment
ASAKURA Posted November 14, 2011 Author Share Posted November 14, 2011 I also played with hiding the caption of each thumbnail in order to do some image wall and this one looks quite nice. I've uploaded a second sample (mymusicfiles.zip).. Christian hi,good job, but when viewing in a listview there is no list control... Quote Link to comment
ASAKURA Posted November 14, 2011 Author Share Posted November 14, 2011 (edited) Ещё одно меню неправильно отображается. Название меню дай. Хотелось бы иметь подсказки в основных меню, примерно такие. ну извиняй, я просто не вижу в них смысла.... ну если будет время попробую тебе облегчить жизнь. Основное меню у Вас на скриншоте выглядит супер, у меня по-другому. Как сделать как у Вас? Скриншоты прилагаю. С уважением. Меню что у меня - это меню медиа портала,я маленьким сереньким не пользуюсь (который у тебя первый скрин). Если возможность будет и время. могу сделать и (серенькое меню) меню как главное. Вот фикс, посмотри и отпишись, если есть у тебя аська напиши номерок в ЛС. DialogDateTime.xml Edited November 14, 2011 by Starkun Quote Link to comment
Maraga Posted November 14, 2011 Share Posted November 14, 2011 I'm interested in this topic, but can we keep the language in english or german in this topic, so that the rest of the world can follow it? Mark Quote Link to comment
ASAKURA Posted November 15, 2011 Author Share Posted November 15, 2011 (edited) to Maraga I'll try, but my English is very bad, I can read and understand what is written, and German, I do not know. In the previous message nemosja asked to create tips for the OSD buttons. and change for DialogDateTime.xml Edited November 15, 2011 by Starkun Quote Link to comment
nemosja Posted November 15, 2011 Share Posted November 15, 2011 I too am sorry and I have very bad English Quote Link to comment
nemosja Posted November 15, 2011 Share Posted November 15, 2011 Example of good skin Quote Link to comment
ASAKURA Posted November 15, 2011 Author Share Posted November 15, 2011 link for this skin please Quote Link to comment
nemosja Posted November 15, 2011 Share Posted November 15, 2011 Starkun, номер моей аськи 626496567 Quote Link to comment
arbist2005 Posted November 17, 2011 Share Posted November 17, 2011 NeutrinoCL for Xperience OSDskin NeutrinoCL Xperience.rar Quote Link to comment
moremax Posted November 20, 2011 Share Posted November 20, 2011 Hi found some bug in Channel EPG when Red button is pushed... Regard Oliver Quote Link to comment
moremax Posted November 23, 2011 Share Posted November 23, 2011 hallo, do have seen my post? Quote Link to comment
ASAKURA Posted November 25, 2011 Author Share Posted November 25, 2011 Hi, sorry, no time! try this one DialogDateTime.xml Quote Link to comment
ASAKURA Posted February 28, 2012 Author Share Posted February 28, 2012 Skin update - 28.02.2012 Quote Link to comment
