After Cutting is audio longer than video
Memphis
I've recordet with the Videorecorderplgin in ts with the newest Version of DVBViewer. I've recordet 24 Episodes from KoQ. 23 of them habe the same duration. But one of them not.
I have demuxed with ProjecX (newest Version) and when I cut with Mpeg2Schnitt, than the duration agrees no longer.
Momentarily is the differentiated about 6 Seconds. So, i've cut at the Beginning and at the End approximately 1 Seconds. When I show these, the duration from the Video are 20:32:21. the Audio has 20:32:02. THAT ARE 19 Seconds.
What can I do, to fix that?
I would be pleased a fast answer. I'll burn the DVD for a friend, who leaves today.
Please help me.
Memphis
Well I have no clue, but I'll try to help anyway. :P
If You still have the original: Try to give pvastrumento a try.
Maybe there are problems in the stream and projectx-setting say to discard them. But normally the same should then be done to the video and audio acordingly.
Try to change the settings not to discard anything.
What if you simply watch the original file? Async??
If not-> Try IfoEdit to make a DVD-VOB and burn onto DVD.
Well these are my ideas by now. But as said: I have no clue.
Good luck!
:D
is audio only longer or have you a time differece between audio and video?
Steffen
