OSD Neron's Pack
Neron
Hi everybody ;) Here's a WIP version's of my skins ( dreambox rebuild to DVBViewer)
Realse date ? hmmmmmmmmm...
Greeets ;)
Edited by Neron
  • Like 1
  • 5 months later...
where is the link to download OSD Neron's Pack
how can i download OSD Neron's Pack please
Hi Neron, nice Job, but verrry bad that you don´t answer since März...
  • 1 month later...
Hey. These skins are fantastic. Any chance you will share them? :)
  • 5 months later...
Hi guys ;)
here is it a DOWNLOAD link for my Beyond skin from Dreambox conversion to DVBViewer . Skin use X-Skin as a default (only osd and neutrinoCL are modified) . OSD Background's are in images folder named DVDPLAYER , default is silver ,just rename other png file to dvdplayer.png.
plugins not included (use miniepgvars.dll and neutrinocl)
greets
Hi, there ist no Folder "DVDPlayer" in unpacked Zipfile of your present download...
Folder ?? i sad a png file
..BeyonceNeronBlue\Images\
there you have :
dvd_player.png --> main osd background
if you want use another background just rename file e.g dvd_playerOK.png to dvd_player.png (DVBViewer must be off)
thats all
language is universal (from you DVBViewer settings) only channel on my screen is from poland
Then i didnt understand what you ment or whats the meaning of your post... you wrote: "OSD Background's are in images folder named DVDPLAYER , default is silver ,just rename other png file to dvdplayer.png.........." of witch Skin, for what do i need your Download, what happens at all with the Screens that you post?!?!
Edited by moremax
  • Like 1
You really dont understand me ?? download skin , put in osdskins folder and select in DVBViewer... when you want change from silver to blue just rename png file... (background theme)
post-108245-0-74110700-1365881084_thumb.png - silver version
post-108245-0-91108600-1365881095_thumb.png - blue version
Edited by Neron
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
The download link above no longer works - if anyone could make this skin available again I'd appreciate it. It looks good.
  • 4 months later...
You're welcome.
In my opinion you should pin this thema because it's hard to find it ;) , for me that's the best osd-skin for our DVBViewer ;)
hbbTV is not working with this skin.
Did anybody know how to modify this skin to get working HbbTV ?
  • 9 years later...
when new update ?
  • 4 months later...
osd time not work, i use BeyonceNeronBlue, i put 60 second but osd not stay after change programs,  it is bug ?
i use latest pro beta 7.2.4.2
  • Like 1
  • 9 months later...
Replace this attached file with the one in the directory C:\Program Files (x86)\DVBViewer\OSDSkins\Beyonce MOD, this fixes the SNR error and shows the percentage of signal received correctly.
myMiniEPG.rar.zip
  • 3 weeks later...
I added more options in it, improving the previous one.  Replace this attached file with the one in the directory C:\Program Files (x86)\DVBViewer\OSDSkins\Beyonce MOD
myMiniEPG.zip
