Martin Lebeda
XBMC and Skystar USB HD 2 CI
Martin Lebeda
Good evening,
i am trying for few weeks establish Satelite TV on XBMC 12 through recording service. Everything is working fine instead of switching channels. It will stuck on channel change. At lower right corner shows its doing something but program change does not work.
I tried USB DVB-T dongle Aver Media - AVerTV Hybrid + FM Volar and worked great. Is something in configuration service which is specific for SKYSTAR? I must mention, that in DVBViever channels change without problem for SKYSTAR too. Using Windows 8 64-bit Professional. TechniSat Skystar USB HD 2 CI drivers version: 1.0.6.102. Downloaded somewhere from google. (have not found on offi site - it looks like they dont support this model anymore)
Regards
Martin
Share this post
Link to post
Martin Lebeda
How can I check if recording service is going ok? Which player can use it? Bought it cause i want it on XBMC. I am still not sure if its service case or XBMC. Or want send some logs? Just which and where to find them.
Share this post
Link to post
Martin Lebeda
Found few interesting things. When i get only 3 channels in favorites i can switch two of them (CT sport and CT 2(qaa)). Switching works fine until i want switch to "CT 1(qaa)". Found log (C:\ProgramData\CMUV\DVBViewer\svcdebug.log)for card which says nothing, it does not matter if channel stuck or i change.
Log:
CT sport (ok):
19.03.13 20:21:59.298 Release              TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.740 tStreamClient        Release          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.740 tStreamClient        Destroy          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.865 tStreamClient        Destroyed        TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.865 tStreamClient        hamDeleted       TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.865 TRecordingEngine     Releasereference TStreamClient: 1
19.03.13 20:22:05.877 TRecordingEngine     AddReference     TStreamClient: 2
19.03.13 20:22:05.890 TBDATwinhan          Opendevice       bvTwinhan
19.03.13 20:22:05.991 tStreamClient        AllocateHardware TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:05.991 TBDATwinhan          SetTuner         TType: 1, Freq: 12525, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 1, DiseqC: 0, FEC: 3, APID: 102, VPID: 166, PMT: 1030, SID: 8007, SatMod: 1, DiseqCVal: 0, NID: 3, Flags: 25
19.03.13 20:22:06.359 TBDACITwinhanModule CI Base SetTuner Entering
19.03.13 20:22:06.359 TBDACITwinhanModule CI Base SetTuner Leaving
19.03.13 20:22:06.359 AllocateHardware     TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:22:06.399 TW MMI               TSD Crypt CW
19.03.13 20:22:06.489 TBDACITwinhanModule WinProc Received PMT ready
19.03.13 20:22:09.350 Release              TechniSat UDST7000BDA DVBS Tuner
_____________________
CT 2(qaa) OK:
19.03.13 20:23:01.976 tStreamClient        Release          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:01.976 tStreamClient        Destroy          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:02.096 tStreamClient        Destroyed        TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:02.096 tStreamClient        hamDeleted       TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:02.096 TRecordingEngine     Releasereference TStreamClient: 1
19.03.13 20:23:02.097 TRecordingEngine     AddReference     TStreamClient: 2
19.03.13 20:23:02.112 TBDATwinhan          Opendevice       bvTwinhan
19.03.13 20:23:02.213 tStreamClient        AllocateHardware TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:02.213 TBDATwinhan          SetTuner         TType: 1, Freq: 12525, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 1, DiseqC: 0, FEC: 3, APID: 92, VPID: 163, PMT: 1027, SID: 8004, SatMod: 1, DiseqCVal: 0, NID: 3, Flags: 25
19.03.13 20:23:02.659 TBDACITwinhanModule CI Base SetTuner Entering
19.03.13 20:23:02.659 TBDACITwinhanModule CI Base SetTuner Leaving
19.03.13 20:23:02.660 AllocateHardware     TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:02.671 TW MMI               TSD Crypt CW
19.03.13 20:23:02.729 TBDACITwinhanModule WinProc Received PMT ready
19.03.13 20:23:05.699 Release              TechniSat UDST7000BDA DVBS Tuner
____________
CT 1(qaa) stuck:
19.03.13 20:23:55.256 tStreamClient        Release          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.256 tStreamClient        Destroy          TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.371 tStreamClient        Destroyed        TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.371 tStreamClient        hamDeleted       TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.371 TRecordingEngine     Releasereference TStreamClient: 1
19.03.13 20:23:55.375 TRecordingEngine     AddReference     TStreamClient: 2
19.03.13 20:23:55.389 TBDATwinhan          Opendevice       bvTwinhan
19.03.13 20:23:55.490 tStreamClient        AllocateHardware TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.490 TBDATwinhan          SetTuner         TType: 1, Freq: 12525, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 1, DiseqC: 0, FEC: 3, APID: 88, VPID: 162, PMT: 1026, SID: 8003, SatMod: 1, DiseqCVal: 0, NID: 3, Flags: 25
19.03.13 20:23:55.864 TBDACITwinhanModule CI Base SetTuner Entering
19.03.13 20:23:55.864 TBDACITwinhanModule CI Base SetTuner Leaving
19.03.13 20:23:55.864 AllocateHardware     TechniSat UDST7000BDA DVBS Tuner
19.03.13 20:23:55.897 TW MMI               TSD Crypt CW
19.03.13 20:23:55.973 TBDACITwinhanModule WinProc Received PMT ready
19.03.13 20:23:58.019 Release              TechniSat UDST7000BDA DVBS Tuner
Image of stuck XBMC (CT Sport -> CT 1)
Edited by Martin Lebeda
Share this post
Link to post
Martin Lebeda
Tried to connect on local computer like wiki said and its working. Removed connection to satellite in DVBViewer - Settings - Hardware. Swtiches channels without problem.
Tried from another computer in home network via web port 8089 RTSP (m3u) - Nova HD channel works great with VLC media player for 15s, then stuck and needs to run m3u again via web browser link to view another 15s. :) Strange is that if i choose another channel it will show the first channel i tried. (Nova HD)
Now i can play only CT Sport on XBMC...
Share this post
Link to post
Martin Lebeda
Direct streams via web interface works great.
Share this post
Link to post
Tjod
A Bug in VLC http://www.DVBViewer.tv/forum/topic/51714-rtsp-streaming-with-vlc-client-crash-every-20sec-aprox/#entry382223
For VLC use the non RTSP version.
If there are no problem with the DVBViewer as client. May be the topic about the XBMC DVBViewer Recording Service PVR Plugin is a better place for this question.
http://forum.xbmc.org/showthread.php?tid=140645&pid=1370696#pid1370696
http://www.DVBViewer.tv/forum/topic/47467-integration-with-xbmc-pvr/
I don't use XBMC.
Share this post
Link to post
Martin Lebeda
I don't use XBMC.
Thank you useful informations. I just wanted to be sure it is no problem in service. Now i try XBMC forum.
Thank you for your time. :)
Martin
Share this post
Link to post
Martin Lebeda
Last question. Can i use Recording service on one PC and DVBviever on another? Or need to buy another licence? Or i will break licence agreement if i install DVBViever on PC, then remove it and install on another PC of mine?
Share this post
Link to post
Griga
It is tolerated as long as DVBViewer / RS are used on different PCs only by you or close relatives in a single household. However, take care that no one else uses your username and password. Members area access by different people with the same credentials will lead to trouble. With other words: You have to do all downloads and updates.
Nevertheless I think it would be just fair to buy a second licence if let's say you and your son are using DVBViewer extensively and independently on different PCs.
Share this post
Link to post
Martin Lebeda
Your licence politic makes me happy. If i use it more at home, i will buy more licenses. Whole DVBViewer team deserves it. :)
Share this post
Link to post
  • Similar Content
    • Palomino3000
      By Palomino3000
      HI,
      I have win10-64 bit and I have a big problem.
      I have done multiple installations of dvbviever.
      Program Files\DVBViewer     ----> CMUV\DVBViewer   (sat usb card)
      Program Files\DVBViewer 2   ----> CMUV\DVBViewer 2  (sat pci card)
      Program Files\DVBViewer 3   ----> CMUV\DVBViewer 3 (dvdT usb card)
      Program Files\DVBViewer 4   ----> CMUV\DVBViewer 4  (use only for iptv)
      etc etc
      Program Files\DVBViewer 8   ----> CMUV\DVBViewer 8 (use only for iptv)
      Program Files\DVBViewer 9   ----> CMUV\DVBViewer 10 (use only for iptv)
      the problem is if I launch DVBViewer 1 - 2 - 3 - 4 - 5 -6 - 7 -8 start all OK,
      then the (9) nine installation don't start!!! Even 10 and following....
      only 8 instances of dvbviwer at the same time!!!!
      why???
      is there a way to solve the problem?
      thanx!!
    • NetRider
      By NetRider
      ich bin neu hier und möchte euch kurz mein Problem schildern, in der Hoffnung das Ihr mir helfen könnt.
      Aufgrund eines Mainboardwechsels konnte ich meine alte PCI Technisat DVB-S2 Karte nicht mehr verwenden.
      Ich habe mich daraufhin für die DVBSKy S950 entschieden und diese heute installiert.
      Gleich vorweg, ich habe den Stromanschluss an der Karte nicht angeschlosen, da der LNB komplett versorgt ist.
      Nach der Installation sind leider nur die öffnentlich rechtlichen ARD, ZDF usw. inkl. deren HD Versionen zu empfangen. Diese laufen sehr gut und ohne Probleme.
      Sobald ich VOX, ProSieben o.ä. also einen Privatsender anschalte kommt jedoch kein Bild.
      Kennt jemand das Problem? Einstellung falsch? Ich stehe hier gerade ein wenig auf dem Schlauch ...
      Vielen Dank schon mal im voraus für eure Hilfe.
      MfG
      Marcus
    • kafisc
      By kafisc
      Hi zusammen,
      heute bin ich auf ein komisches Phänomen gestoßen.
      Das Programm "Das Erste HD" auf Astra 19.2E läuft mit dem DVBViewer ohne Probleme (Win10 64bit 1709, DMS 2.0.4.0, DVBV 6.0.4.0).
      Sobald ich jedoch versuche das Programm über den DMS zu schauen, passiert nichts.
      Das ist der einige Sender, der von dem komischen Verhalten betroffen ist. Alle anderen Sender haben diesen Problem nicht.
      "Das Erste HD" auf Kabel UM läuft ohne Probleme auf dem DVBViewer und dem DMS.
      Anbei findet Ihr den exportieren Sender, sowie die support.zip und die datei streaming.m3u (Das Erste HD Playlist Sat".
      Probiert habe ich bisher ohne Erfolg:
      - Neustart DMS
      - Neustart PC
      - Sender gelöscht und durch neuen Sendersuchlauf hinzugefügt
      - Sender umbenannt
      VLC wirft den folgenden Fehler:
      Debug-Log DMS:
      Über Tipps würde ich mich sehr freuen.
      Vielen Dank im Voraus & viele Grüße
      kafisc
      Das Erste HD (AC3,deu).ini
      streaming.m3u
    • Peter46
      By Peter46
      ich habe den Recording Service laufen. Am PC mit Viewer kann ich diesen ohne Probleme benutzen. Ich habe allerdings einige Ports abgeändert und Benutzername / Passwort eingerichtet.
      Mit der Android App kann ich auf die Senderliste zugreifen, sehe den Status, kann aber keinen Stream starten. Weder direkt noch transcodiert (auf mehreren Geräten getestet).
      Service und Handys sind in verschiedenen VLANs. Firewallregeln sollten richtig gesetzt worden sein, in den Logs sehe ich keinen Block.
      Ich bekomme folgende Fehlermeldung:
      Ort http://Benutzername:Passwort%40IP:Port_für_Weblogin/upnp/channelstream/2359890544166710168.ts kann nicht abgespielt werden.
      Weder mit VLC noch mit MX Player.
      Hat jemand eine Idee, was ich falsch konfiguriert habe?
      Viele Grüße Peter
      Edit: sehe gerade ich bin im Forum in der falschen Version. Es läuft 1.33.2.0
    • nacode
      By nacode
      Habe einen Megasat IP Server Twin an meine TV Antenne angeschlossen. Diesen Anschluss hatte ich vorher mit einer TV Karte auf Funktion geprüft. Mit der TV Karte werden alle Sender auf Astra 19,2 korrekt erfasst und dargestellt. Da ich die TV Signale jetzt im LAN nutzen möchte habe  ich den Megasat IP Server Twin angeschlossen und meinen DVBViewer Pro für den IP Betrieb konfiguriert.  Danach habe ich einen Suchlauf gestartet. Hat auch funktioniert aber es werden nur 12 Sender gefunden. Einmal SES Astra 4k Stationen und zweitens STN PLC Teststationen.
      Dort wird auch Bild und Ton angezeigt, wobei mein Laptop allerdings mit der Verarbeitung der 4K Bilder Probleme hat, es ruckelt aber die Bilder selbst sind ok.
      Als Anfänger mit dem DVBViewer Pro und dem IP Server hätte ich gerne einen Hinweis was ich konfigurieren müsste um alle Sender des Astra 19,2 zu sehen
