Does dvbviewer work with Win 7 64 bit
rafi
I would like to know if I can use my DVBViewer now with Win 7 64 bit ,include the standard MCE remote control .
I tried it about 3 years ago with 64 bit ,but the remote didn't t work,
Rafi
Link to comment
Hi rafi,
DVBViewer and the Recording Service work flawlessly on Windows 7 x64 and Windows 8 x64.
I cannot tell you about compatibility of the standard MCE remote control, though. Personally, I use an iMON remote which works fine on Windows 7/8 x64.
Kind regards,
GruberMa
Link to comment
Hi GruberMa,
Thanks for your reply, I have Aim RC118 remote with four buttons in the bottom ,I remember these buttons did not work with 64 bit,
Regards,
Rafi
Link to comment
Hi GruberMa,
Regards,
Rafi
Have you tried using EventGhost?
Link to comment
