NIKKOpooh Posted November 28, 2013 Share Posted November 28, 2013 (edited) DVBViewer 5.2.9.0 recording services 1.2.7 Windows 8 x64 Hardware : AMD althlon X4 605e with a dual tunner tv card. i have recently encountered the problem of recording it also happens in 1.2.4 before with the log files like below Device: Digital TV (1) 0:46:22 / 0:00:00 (~ 0.00 MB) Start 0:46:22 / 0:00:00 (~ 0.05 MB) Errors: 66 0:46:23 / 0:00:01 (~ 1.24 MB) Errors: 176 there are continous error in every second. The recored TS is laggy and with blocks on the images. it can't be played as the player will be freezed in a few seconds. I think the reason was just a moment of unstable signal, which can be easily resolved by clicking "rebuild graph" when watching liveTV with DVBViewer. Is there any option that can automatically "rebuild graph" while recording ? Or at least let me know the recording is with error, i can stop and restart it manually. It is really frustrated to see a TS with error after you have recorded an two hour tv show. Edited November 28, 2013 by NIKKOpooh Link to comment
Sherry Posted November 29, 2013 Share Posted November 29, 2013 (edited) > Is there any option that can automatically "rebuild graph" while recording ? During recording the recording service uses no graph. The graph is only needed for playback. So rebuilding graph makes no sense there and would not help. If your playback freezes on an recording error, you should try a different video codec or maybe splitter. I have no such problems, the image recovers by itself after such errors. I use the powerdvd or LAV codecs, both work fine. Errors in the recording can also be repaired / removed with tools like TS Doctor (www.cypheros.de). Edited November 29, 2013 by Sherry Link to comment
McenterFreak Posted November 29, 2013 Share Posted November 29, 2013 You should check your signal. The wiring and connectors should be of good material. Connectors should be HF shielded. Don't use cheap cable splitters Link to comment
NIKKOpooh Posted December 1, 2013 Author Share Posted December 1, 2013 i have checked my signal and it 's ok. So there is no other way to avoid recording corrupted ts stream ? Link to comment
Derrick Posted December 1, 2013 Share Posted December 1, 2013 How did you check your signal? Link to comment
McenterFreak Posted December 2, 2013 Share Posted December 2, 2013 Many people check the signal by their TV, if it is fine there, everything should be okay, BUT TV tuners in Pc's are very often weaker, so TV okay, but recordings in Media Centre not okay. I Know, i have BEEN there!. The last thing i have done, is that my connectors on my sattelite dish has been done by a professional, with a special Tool, where the connectors have been pressed around the cable. Before this was done, the cable sometime fell out of the connector, even if i was very carefull to tighten them. Proffesional cabling/connectors, highly recommended!! Link to comment
rubberfingers Posted December 10, 2013 Share Posted December 10, 2013 Hello I have exactly the same error - the recordings fail unless I manually tune into the channel first on DVBViewer, leave it on that channel then schedule a recording. If the recording service has to change channels it fails with corrupt stream Link to comment
klin Posted February 27, 2014 Share Posted February 27, 2014 Hi Had exactly the same problem - two EyeTV tuners on a Windows7 laptop, no problem with recording. Then I bought a ASUS VivoPC to use as recording server, and i got exactly your problem when recording a lot of bit errors when recording. But now i just found the source of the problem - the WLAN adapter in the PC - when i disabled that every thing works ok. Now i have recorded for 20 minutes without any errors. Link to comment
eleijen Posted March 28, 2016 Share Posted March 28, 2016 Wow, that did it for me too. Using an Intel NUC, disabled the Wifi and it runs fine again. Thank you ! Link to comment
