Full screen image for Radio station
bccrew
Hello,
I was wondering if it's possible to render a still image for a Radio Channel. Right now when tuning to a dvb-c radio channel the screen just stays black.
It would be nice to load a full screen image per station. (logo, wallpaper, etc)
Thank you
  • 3 weeks later...
No good idea? It's quite useless listening to a dvb-c radio station with a black screen now :)
It would be nice to have some indication which channel is playing...
There is a solution for the black screen ;)
Options > Music> Visual Effects
And for the informations, you could disable the time out from the MiniEPG.
Therefore edit the configuration folder\windowdef.xml
And replace
<Window Name="Miniepg Window" ID="500"/>
with
<Window Name="Miniepg Window" ID="500">
<allowtimeout>0</allowtimeout>
</Window>
then the MiniEPG will not disrepair if you open it with OSD-OK [return]
I don't think there will be a Radio OSD mode in the near future.
  • Like 1
Nice, this is kinda what I was looking for :) Just to see the channel name.
Thanks for the tip!
