qquiderr Posted May 26, 2015 Posted May 26, 2015 Hi, its possible make fillter for epg for favourites? Currently epg shows for all channels and epg filter/function for show only favourites is not included. So on satellites is many programs, on multiple systems (multifeed/motorized) is too many channels, its possible to make function/filter that show only favourites? Quote
Cian Posted May 26, 2015 Posted May 26, 2015 (edited) On the Menu click: TV/Radio -> Channel Editor. Then select the "Edit Fav." button at the bottom right-hand corner. Drag and drop the channels into the order that you want. Make sure you save the changes. This will populate the Favourites list on the menu. Click on the EPG button and change the Filter drop-down menu setting on the top right-hand corner to "Favourites" Edited May 26, 2015 by Cian Quote
