support for MIS (multistream tp)
qquiderr
Its on plan to add mis support? With ebs pro working perfectly with stream selection, but DVBViewer tune first stream only, its on plan to add mis support like ebs pro and others?
  • Like 1
..has been asked before. Only tuning that complies with DVB BDA will be supported.
  • Sad 1
if "bda" not support mis and pls, why ebs pro can work with mis and pls? If someone know how ebs pro working, can be his method implented to DVBViewer?
Hi @qquiderr,
Yes. EBS while 'blindscan' can detect MIS codings.
But, with EBS viewing, only VLC, PotPlayer etc.
So, another source will be use.
Demodulator of your TV card; MIS even if not support, can you watch over the EBS ? + VLC or PotPlayer
Your tv card mark/model ?
Here is some pictures ;) If it works with ebs pro, maybe can be implented to DVBViewer too. ;)
Your card supported direct. ( TBS 5980 )
* Demodulator ; stv903bac : For QPSK, 8PSK, ACM/VCM and T2 MI coding support. ( Under Windows. )
So, you can watch DVBViewer.
DVBViewer authors will describe what you should do.
Edited by serkanguzel
  • 3 months later...
How can i do this? Exist any extension or something that works with supported cards?
Sorry... I checked again.
TBS 5980 STV0903bac demodulator, restricted make MIS + PLS.
So, for STV0903bac demodulator, endirect support. TSreader, Crazyscan, EBSpro etc.
Direct support demodulators ;
* STV0900aac( TBS 5925, 6925 )
* STV0910ad( TBS 6983 )
  • 3 weeks later...
I have TBS 6983 i can get DVBViewer to find the chanels but playing them is terrible, MIS is supported in both dvbdream & progdvb.
dvbdream/progdvb with this you can do, but on here live from RS-Service. MIS in DVBViewer give it not and come not,
  • 6 years later...
HI,
9E Multistream found DVB Viwer, 33,34,35,36
others (MIS) 1,2,3,4,5,11,101,23,24,25 not detected.
How to EBSpro or CrazyScan?
with CrazyScan I get error message 0xc000007b and with EBSpro after scanning, can't the video start?
TBS-6590
not supported?
16APSK, 32APSK demodulator, also supports CCM, VCM, ACM mode, multiple transport stream and Generic Stream reception?
But the signal in TransEdit detects the frequency, so how to lock it?
