Cian Posted December 1, 2015 Share Posted December 1, 2015 Hi, 1. When I upgraded from Wndows 7 to Windows 10, I lost the programme description window in file manager. Is there any way to view programme detail this without starting DVBViewer? 2. I have DVBViewer pinned to the menu bar at the bottom of the screen. When I right-click, I have the option of opening three channels directly - ZDF, ARD and RTL. Can I configure this for my own favourites? Thanks, C. Quote Link to comment
Tjod Posted December 1, 2015 Share Posted December 1, 2015 1. As far as I know not. You could enable the generation of EPG info file. Then you get a .txt file with that informations. 2. in the jumplist.ini entry name = DVBViewer command line parameter there is only a German explanation for this in the Wiki http://de.DVBViewer.tv/wiki/Jumplist.ini Quote Link to comment
Cian Posted December 1, 2015 Author Share Posted December 1, 2015 (edited) Thanks. You could enable the generation of EPG info file. Then you get a .txt file with that informations. It is hand to be able to click on a recording and see the episode number. I can cope with having to open the file first and look on the playback window. C. Edited December 1, 2015 by Cian Quote Link to comment
