Eyerex
Move channels to different group
Eyerex
Is there an easy way to move more than one channel at a time to a different group ?
Share this post
Link to post
Griga
Not yet. Work is in progress. Multi-selection in the DVBViewer Pro channellist editor will be available in the next release.
Share this post
Link to post
Eyerex
Ok cheers for the info :)
Share this post
Link to post
majstang
How would you do that? Isnt the ChanneList a TreeView control? MS does not support TV Multi-select yet to my knowledge (well if trying to implement it it works really crappy...at least for me :blushing: )
EDIT: Aha, its a Virtual Treeview (special built for Delphi) and it supports multiselect. Far out, cool! Wish i could use it :original:
Edited by majstang
Share this post
Link to post
Tjod
The DVBViewer GE has support for selecting multiple channels in the channel list editor for some time.
Share this post
Link to post
Griga
The Windows treeview component supports multi-select, or at least the Delphi VLC wrapper does. However, it's quite limited, so I preferred to do my own stuff in DVBViewer GE. A selection list object in the background kind of forces the Windows treeview to do what I want.
The Virtual Treeview in DVBViewer Pro is much more flexible, but also has its pitfalls, particularly when it comes to drag & drop in combination with multi-select as I experienced today... ;)
Share this post
Link to post
SimonP
Will sorting be added as well? It's a real pain having to look through 100's of channels on a satellite looking for one when they're out of order.
Share this post
Link to post
Tjod
You could use a spreadsheet application to sort the channel list. :innocent:
Export the channel list as .csv open it then with a spreadsheet application. Sot it there and save it again as .csv.
And delete all channels in the DVBViewer and import the sorted .csv channel list.
But this is only useful if you know how to work with a spreadsheet application, you like to change a lot. And only because there are currently no good solutions inside the DVBViewer Pro ;)
Share this post
Link to post
SimonP
I'm not sure why it's been overlooked for all these years but thanks for the suggestion, it's certainly one solution to the problem.
Share this post
Link to post
Griga
There are sorting options in the channel list, but they just influence how it is displayed. They don't apply to the editor.
In the next release at least alphabetical sorting will be available in the editor, and it will change the order of folders and channels permanently. Here is an overview of the new features:
- Multi-select of channels or category folders in the channel list editor and favourites editor. It applies to the following functions: Export, Drag & Drop, Cut, Copy, Paste, Delete, Alphabetical Sorting
- Cut, Copy and Paste for moving a selection of channels or categories within the channel list and favourites editor, for copying items from the channel list to the favourites and for data exchange with DVBViewer GE and TransEdit.
- Select All selects all siblings of the selected item within a folder resp. caterory.
Share this post
Link to post
Eyerex
Cheers for the update
Ps when may we see the next update :)
Share this post
Link to post
hackbart
I assume not this year :) I currently got stuck with the HbbTV part, which will have several bigger improvements till the next release. Which means trimming the source and attempting removing work arounds.
Both have to become tested before we publish an update.
Share this post
Link to post
