Streaming Options gone in RS 1.32.0.0
Chrisw74
I have recently updated the recording service from 1.30 to 1.32 but have found that when trying to create a transcoded stream there are many options missing, one of the options I liked in the old version was the ability to choose a port number to stream from (as I prefer not to stream from the standard port of 8089), does this option still exist.
Also in version 1.30 I made some custom presets and saved them, does anyone know if these presets can be used in version 1.32? Below is an example of one the custom presets made, which has been taken from the webstream.ini file, can these just be pasted into the new ffmpegprefs.ini?
[Main]
Port=8837
[Preset.7]
Name=H2641536kbMP364
Muxer=0
UseVideo=1
VCodec=6
VRate=1536
VSize=1.00
UseAudio=1
ACodec=2
ARate=64
AChannels=2
UseHardware=0
Deinterlace=1
Output=http{mux=[muxer],dst=[iP]:[Port]/}
Outputlink=
transcodewrapper=transcode{[AV]}:
Audio=acodec=[acodec],ab=[abitrate],channels=[achannels]
Video=vcodec=[vcodec],vb=[vbitrate],scale=[vscale][deinterlace]
Videocodecspezific=
Link to comment
The very old VLC player based streaming is gone.
The the straming via FFmpeg uses always the web-interface port. You can change the web-interface port in the RS options.
And you can't use this direct in the ffmpegprefs.ini. It is a complete different format.
Link to comment
The [Flash High 1800 kbit] preset should be the nearest to your preset.
It uses H264 and MP3 and the over all data-rat should be the same.
But there audio rat is lower.
Link to comment
Are you sure deinterlace is not already used?
(in direct streamin it is not used)
As far as I can tell the output from FFmpeg isn't interlaced any more.
Link to comment
