Tuner problems (Anysee E7 T2C - with CI)
danhelp
I'm having problem use the above tuner.
If i'm using DVBViewer in normal mode, it decrypt just fine,
but then using "DVBViewer Recording Service" it won't decrypt channels
- only free to air i working.
Is there any solution fore this?
HELP Please....
Link to comment
The hardware is configured different in the RS.
In the DVBViewer "Use internel Network Provier filter" is enabled in the RS it is disabled.
That can be the reason.
And in the RS is the EPG resection disables. You should enable this as well.
And to use DVBViewer and RS in combination. The control over the hardware must be by the RS.
http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
Link to comment
