Bug in Rebuid Recording History
Mr. Man-wai Chang
File naming scheme: %station\%year-%date_%time_%station_%name
When I selected RRH in Tasks via RS' webinterface, it didn't scan sub-folders in the recording folder. Each sub-folder was named after the channel (that is %station).
BTW, how could I manually repair/edit the recording list?
Edited by Mr. Man-wai Chang
Link to comment
Recursing sub-folders to the recording folder when Rebuilding Recording History works fine here. Make sure to Refresh the DB afterwards to see the results.
The recording history can be found in the SvcDatabase.db3.
Edited by majstang
Link to comment
Do i need to keep the recording.txt files when recording for the rebuild to work?
edit:
I found that when I accessed the web interface at localhost, the recordings were listed properly.
However, when I used a remote PC to access the web interface, no recording was listed.
edit again:
Clearing web caches fixed the problem. Oh well... -_-"
Link to comment
I found that it's an SQLlite file. How can I edit it manually?
Link to comment
Probably with an SQLite editor, but I dont know how RS would react to changes like that.
Link to comment
Thanks!
Link to comment
