LearningCurve Posted March 13, 2016 Share Posted March 13, 2016 (edited) Running the latest versions of DVBViewer and Transedit on Windows 7 32bit. With the HVR-950 I can scan atsc channels and view them in Transedit but I get nothing in DVBViewer. After attempting to scan in DVBViewer, it will not work again in Transedit until I reboot. Scanning devices again does not help. I have two AverMedia atsc tuners that work fine. All three tuners were used with older versions of DVBViewer running on windows Xp in 2011. This is on a fresh install of windows 7. I started with the latest drivers for the HVR-950, then tried older drivers with the same results. support.zip Edited March 13, 2016 by LearningCurve Quote Link to comment
Tjod Posted March 13, 2016 Share Posted March 13, 2016 Try if changing the the settings (options > hardware) "Direct tuning" or "Use internal Network Provider filter" for the card changes anything. Quote Link to comment
LearningCurve Posted March 13, 2016 Author Share Posted March 13, 2016 Before, I had tried every combination of "Direct tuning" or "Use internal Network Provider filter" possible with no luck. After your post I tried it again and when it failed rebooted before trying another combination. After a fresh boot, Turning off "Direct Tuning" is what worked. Thanks Man! Quote Link to comment
