Frequency scaning, recognition and identification process on QPSK2
azimli
Hi masters,
There is a frequency as in the picture ;
1. For QPSK, scan parameter selection placing.
2. Recognition and representation in the channel and frequency characteristics.
Is it possible to add these features of the program ?
Best regards.
Edited by azimli
  • Like 1
Link to comment
sorry that is outside the scope. Only tools with direct hardware controlled interfaces can read such information. Besides IMHO QPSK2 doesn't exist :rolleyes:
Link to comment
Firstly, DVB Player must support the feature.
Well, is DVBViewer support ? No.
So, under the appropriate hardware, DVD Player should display.
In my opinion.
Link to comment
If Microsoft adds a standardised method, to the BDA driver to get the information about tuning parameters back from the driver. Then there is a chance it will bee supported by the DVBViewer.
But as long as it is only possible via proprietary vendor specific functions, I don't think that it will be supported.
Link to comment
Modulation parameters for DVB-S2 are: QPSK, 8PSK, 16APSK, 32APSK
http://www.etsi.org/deliver/etsi_en/302300_302399/30230701/01.04.01_60/en_30230701v010401p.pdf
And even in DVB-S2X QPSK2 isn't mentioned at all.
http://www.etsi.org/deliver/etsi_en/302300_302399/30230702/01.01.01_20/en_30230702v010101a.pdf
So where is the standard defining DVB-S2 and QPSK2?
And it is very unlikely the things (especially relating hardware support) get implemented in TransEdit which are not supposed to go into the DVBViewer as well.
Link to comment
Puah... What would be the village of you, what town ! :D
Here anyone been talking about standards ?
There's a reality.
If DVBViewer's not covered, a separate issue. OK ???
Let's close this topic. So, accept that no unasked ...
Best regards.
Link to comment
