calande
DVBViewer now freezing for 1 sec. every 2 sec.
calande
Hello,
I'm using DVBViewer 5.6.4.0 with the LAV x86 plugin that is downloaded upon DVBViewer installation. The application has become unresponsive since yesterday. The previous version was also unresponsive yesterday. In Windows, the Task Manager shows very little CPU use (3% max. from DVBViewer). When I select a TV channel from my favorites, I'm able to watch for 2 sec. then, it's the black screen and no sound in the application. When going through the menu on top, it takes 1 sec to react, it's very slow. It can be smooth for 2-3 sec, then it freezes for 1 sec. and becomes usable again for 2-3 sec. I tried changing the DirectX plugin from LAV to default Microsoft, in vain. I'm using Windows 7 64bit. I'm using a dual DVB-T HomeRun tuner from SiliconDust.
Could you help me please?
Thank you,
Share this post
Link to post
calande
I restarted my router, and the problem is gone...
Share this post
Link to post
